주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Game Boy Advance Back Shell Replacement
필요한 것
  1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 2개 중 1개 Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 2개 중 2개
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
    댓글 쓰기
  2. Game Boy Advance Back Shell Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 1개 Game Boy Advance Back Shell Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 2개 Game Boy Advance Back Shell Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 3개
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    댓글 쓰기
  3. Game Boy Advance Back Shell Replacement, Remove the batteries: 3 단계, 이미지 3개 중 1개 Game Boy Advance Back Shell Replacement, Remove the batteries: 3 단계, 이미지 3개 중 2개 Game Boy Advance Back Shell Replacement, Remove the batteries: 3 단계, 이미지 3개 중 3개
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    댓글 쓰기
  4. Game Boy Advance Back Shell Replacement, Remove the back shell screws: 4 단계, 이미지 2개 중 1개 Game Boy Advance Back Shell Replacement, Remove the back shell screws: 4 단계, 이미지 2개 중 2개
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    댓글 쓰기
  5. Game Boy Advance Back Shell Replacement, Remove the back shell: 5 단계, 이미지 2개 중 1개 Game Boy Advance Back Shell Replacement, Remove the back shell: 5 단계, 이미지 2개 중 2개
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
196,872 평판
안내서 1,243개를 작성함
2가이드 댓글
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
rguich - 답글 공유
We've updated the guide, and it now includes the screw measurements.
Spencer Day - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 39
지난 30일: 139
전체 시간: 13,588
