주요 콘텐츠로 건너뛰기
Game Boy Batteries Replacement
Andrew Tramposch
Andrew Tramposch18 다른 기여자
최종 수정일 October 19, 2020
15 초
매우 쉬움
This guide will illustrate how to replace the batteries in a Game Boy system.
필요한 것
  1. Game Boy Batteries Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Game Boy Batteries Replacement, Batteries: 1 단계, 이미지 2개 중 2개
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Batteries Replacement: 2 단계, 이미지 3개 중 1개 Game Boy Batteries Replacement: 2 단계, 이미지 3개 중 2개 Game Boy Batteries Replacement: 2 단계, 이미지 3개 중 3개
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Batteries Replacement: 3 단계, 이미지 2개 중 1개 Game Boy Batteries Replacement: 3 단계, 이미지 2개 중 2개
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
18다른 기여자 명과 함께
Andrew Tramposch
회원 가입일: 06/24/10
2,249 평판
안내서 6개를 작성함
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 35개를 작성함
댓글 5개
This was a very helpful guide. I had no idea how to replace the batteries for my GameBoy, but thanks to this amazing and helpful guide, I was able to do so. The only issue that I have with this guide is that it did not explain how to properly dispose the used batteries. I ended up soaking them in gasoline and lighting them on fire because the colors look super pretty. Don’t breath the smoke though! I’m pretty sure the smoke is toxic?
Mentat - 답글
I have struggled with this for 20 years. Thank you.
Igor Kolosha - 답글
My problem was that I removed four batteries from my Game Boy Classic but only inserted three new ones. It didn’t work. An expert told me to also insert four new ones, it worked.
Akula - 답글
Awesome! I finally know how!
Ethan Sligar - 답글
My wife came back because of this tutorial.
Mia Cipollone - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 55
지난 30일: 215
전체 시간: 22,877
