주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Vivoactive Display Unit Replacement
필요한 것
    1. Garmin Vivoactive Display Unit Replacement, Wristband: 1 단계, 이미지 1개 중 1개
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      댓글 쓰기
    2. Garmin Vivoactive Display Unit Replacement: 2 단계, 이미지 2개 중 1개 Garmin Vivoactive Display Unit Replacement: 2 단계, 이미지 2개 중 2개
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      댓글 쓰기
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: 3 단계, 이미지 1개 중 1개
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      댓글 쓰기
    2. Garmin Vivoactive Display Unit Replacement: 4 단계, 이미지 2개 중 1개 Garmin Vivoactive Display Unit Replacement: 4 단계, 이미지 2개 중 2개
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      댓글 쓰기
    3. Garmin Vivoactive Display Unit Replacement: 5 단계, 이미지 1개 중 1개
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      댓글 쓰기
    4. Garmin Vivoactive Display Unit Replacement: 6 단계, 이미지 1개 중 1개
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      댓글 쓰기
    5. Garmin Vivoactive Display Unit Replacement: 7 단계, 이미지 1개 중 1개
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      댓글 쓰기
    6. Garmin Vivoactive Display Unit Replacement: 8 단계, 이미지 1개 중 1개
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Katie Paswaters
회원 가입일: 10/01/15
532 평판
안내서 1개를 작성함
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 회원
CPSU-MANESS-F15S1G21
4 회원들
안내서 17개를 작성함
40가이드 댓글
Does anyone knows where can I buy a vivoactive display?
dragomariano - 답글 공유
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - 답글 공유
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - 답글 공유
Any links found for replacement screen?
dskggray - 답글 공유
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 135
전체 시간: 105,326
