주요 콘텐츠로 건너뛰기
Google Pixel 3 Front-Facing Cameras Replacement
필요한 것
  1. Google Pixel 3 Front-Facing Cameras Replacement, Weaken the back cover's adhesive: 1 단계, 이미지 1개 중 1개
  2. Google Pixel 3 Front-Facing Cameras Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the heated bottom edge of the back cover.
    • Make sure you did not mistake the screen side for the back cover side.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
    • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
  3. Google Pixel 3 Front-Facing Cameras Replacement, Fingerprint cable information: 3 단계, 이미지 1개 중 1개
    • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
  4. Google Pixel 3 Front-Facing Cameras Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 3개
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
  5. Google Pixel 3 Front-Facing Cameras Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement: 5 단계, 이미지 3개 중 3개
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
  6. Google Pixel 3 Front-Facing Cameras Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement: 6 단계, 이미지 3개 중 3개
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  7. Google Pixel 3 Front-Facing Cameras Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 3개
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
  8. Google Pixel 3 Front-Facing Cameras Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
  9. Google Pixel 3 Front-Facing Cameras Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 3개
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
  10. Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Google Pixel 3 Front-Facing Cameras Replacement, Remove the back cover: 11 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Remove the back cover: 11 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Remove the back cover: 11 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 Front-Facing Cameras Replacement, Remove the screws: 12 단계, 이미지 1개 중 1개
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
  13. Google Pixel 3 Front-Facing Cameras Replacement, Remove the charging coil: 13 단계, 이미지 1개 중 1개
    • Lift up and remove the wireless charging coil.
  14. Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
  15. Google Pixel 3 Front-Facing Cameras Replacement, Remove the screws: 15 단계, 이미지 2개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Remove the screws: 15 단계, 이미지 2개 중 2개
    • Remove the two screws securing the camera bracket:
    • One 4.1 mm Phillips screw
    • One 4 mm standoff screw
    • Standoff screws are best removed using a standoff bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • Remove the camera bracket.
  16. Google Pixel 3 Front-Facing Cameras Replacement, Identify the cameras: 16 단계, 이미지 1개 중 1개
    • If you are replacing front-facing cameras, determine which one you need to replace:
    • Normal view camera
    • Wide-angle camera
    • If you are doing the motherboard removal procedure, you will need to remove both cameras.
  17. Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 2개 Google Pixel 3 Front-Facing Cameras Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the connector for the camera(s) you are replacing.
  18. Google Pixel 3 Front-Facing Cameras Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 1개 Google Pixel 3 Front-Facing Cameras Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 2개
    • The cameras are held in place with adhesive.
    • Insert the point of a spudger behind the edge of the camera module and pry up to loosen it from the frame.
  19. Google Pixel 3 Front-Facing Cameras Replacement, Remove the camera(s): 19 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Use a pair of blunt nose tweezers to remove the camera(s).
    • If the adhesive holding the camera module is in good condition, you can re-use the adhesive. Otherwise, replace the adhesive with double-sided Tesa tape.
    • When installing a replacement camera module, make sure that the phone frame lens are free of adhesive residue or debris.
결론
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,604 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
2가이드 댓글
There is only 1 front facing camera on a Pixel 3
Ashley Gibbon - 답글
Pixel 3 have two front facing cameras but Pixel 3a has only one.
David Martel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 38
지난 30일: 219
전체 시간: 4,291
