주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 3 Motherboard Replacement
필요한 것
    1. Google Pixel 3 Motherboard Replacement, Weaken the back cover's adhesive: 1 단계, 이미지 1개 중 1개
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 3개
      • Apply a suction cup to the heated bottom edge of the back cover.
      • Make sure you did not mistake the screen side for the back cover side.
      • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
      • Lift on the suction cup with strong, steady force to create a gap.
      • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
      • Insert an opening pick into the gap.
      • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Fingerprint cable information: 3 단계, 이미지 1개 중 1개
      • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
      댓글 쓰기
    4. Google Pixel 3 Motherboard Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 3개
      • Slice the adhesive along the bottom edge of the phone and around the right corner.
      • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
      댓글 쓰기
    5. Google Pixel 3 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
      • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
      댓글 쓰기
    6. Google Pixel 3 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
      • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
      댓글 쓰기
    7. Google Pixel 3 Motherboard Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 3개
      • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
      • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
      • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
      댓글 쓰기
    8. Google Pixel 3 Motherboard Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
      • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
      댓글 쓰기
    9. Google Pixel 3 Motherboard Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 3개
      • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
      • Remove the fingerprint connector bracket.
      댓글 쓰기
    10. Google Pixel 3 Motherboard Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      댓글 쓰기
    11. Google Pixel 3 Motherboard Replacement, Remove the back cover: 11 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the back cover: 11 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Remove the back cover: 11 단계, 이미지 3개 중 3개
      • Remove the back cover.
      • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
      • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
      • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
      • Follow this guide to correctly apply new back cover adhesive.
      댓글 쓰기
    1. Google Pixel 3 Motherboard Replacement, Remove the screws: 12 단계, 이미지 1개 중 1개
      • Remove the five Phillips screws securing the wireless charging coil:
      • Two 1.9 mm screws
      • Two 4.2 mm screws
      • One 4.3 mm screw
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement, Remove the charging coil: 13 단계, 이미지 1개 중 1개
      • Lift up and remove the wireless charging coil.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
      댓글 쓰기
    1. Google Pixel 3 Motherboard Replacement, Remove the screws: 15 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the screws: 15 단계, 이미지 2개 중 2개
      • Remove the two screws securing the camera bracket:
      • One 4.1 mm Phillips screw
      • One 4 mm standoff screw
      • Standoff screws are best removed using a standoff bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      • Remove the camera bracket.
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement, Identify the cameras: 16 단계, 이미지 1개 중 1개
      • If you are replacing front-facing cameras, determine which one you need to replace:
      • Normal view camera
      • Wide-angle camera
      • If you are doing the motherboard removal procedure, you will need to remove both cameras.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the connector for the camera(s) you are replacing.
      댓글 쓰기
    4. Google Pixel 3 Motherboard Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 2개
      • The cameras are held in place with adhesive.
      • Insert the point of a spudger behind the edge of the camera module and pry up to loosen it from the frame.
      댓글 쓰기
    5. Google Pixel 3 Motherboard Replacement, Remove the camera(s): 19 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Tesa 61395 Tape
      $8.95
      • Use a pair of blunt nose tweezers to remove the camera(s).
      • If the adhesive holding the camera module is in good condition, you can re-use the adhesive. Otherwise, replace the adhesive with double-sided Tesa tape.
      • When installing a replacement camera module, make sure that the phone frame lens are free of adhesive residue or debris.
      댓글 쓰기
    1. Google Pixel 3 Motherboard Replacement, Disconnect the loudspeaker: 20 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the loudspeaker: 20 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
      • Be careful not to puncture the battery with the spudger.
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement, Remove the screws: 21 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the screws: 21 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Remove the screws: 21 단계, 이미지 3개 중 3개
      • Remove the following four Phillips screws:
      • One 1.9 mm screw
      • One 4.3 mm screw
      • Two 4.3 mm screws with thinner shanks
      • Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
      • The grounding clip installs such that the contoured edge faces the left side of the phone.
      • Remove the small plastic insert from the right side of the USB-C port.
      • Be sure to reinstall this insert before you screw down the daughterboard.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Loosen the loudspeaker: 22 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Loosen the loudspeaker: 22 단계, 이미지 2개 중 2개
      • The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal.
      • Insert the point of a spudger under the bottom right corner of the loudspeaker.
      • Pry up to loosen the loudspeaker from the phone.
      댓글 쓰기
    4. Google Pixel 3 Motherboard Replacement: 23 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement: 23 단계, 이미지 2개 중 2개
      • Insert the point of a spudger under the top left corner of the loudspeaker.
      • Pry up to loosen the loudspeaker.
      댓글 쓰기
    5. Google Pixel 3 Motherboard Replacement: 24 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement: 24 단계, 이미지 2개 중 2개
      • Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
      댓글 쓰기
    6. Google Pixel 3 Motherboard Replacement, Remove the loudspeaker: 25 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the loudspeaker: 25 단계, 이미지 2개 중 2개
      • Remove the loudspeaker.
      • Before you install a replacement loudspeaker, check the adhesive gasket.
      • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
      • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
      댓글 쓰기
    1. Google Pixel 3 Motherboard Replacement, Disconnect the blue antenna cable: 26 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the blue antenna cable: 26 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement: 27 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement: 27 단계, 이미지 2개 중 2개
      • Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clips.
      • The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Disconnect the black antenna cable: 28 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the black antenna cable: 28 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
      댓글 쓰기
    4. Google Pixel 3 Motherboard Replacement, De-route the antenna cables: 29 단계, 이미지 1개 중 1개
      • Carefully de-route both antenna cables and move them away from the charging assembly.
      댓글 쓰기
    5. Google Pixel 3 Motherboard Replacement: 30 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement: 30 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement: 30 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
      • Carefully peel the flex cable from the top of the SIM card reader.
      댓글 쓰기
    1. Google Pixel 3 Motherboard Replacement, Disconnect the display connector: 31 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the display connector: 31 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to carefully pry up the black tape holding the display flex cable in place, near the right edge of the phone.
      • Do not use metal tools to pry, or you may damage the flex cable.
      • Use the flat end of a spudger to pry up and disconnect the display connector from the motherboard.
      댓글 쓰기
    2. Google Pixel 3 Motherboard Replacement, Peel the black tape away from the battery: 32 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Peel the black tape away from the battery: 32 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Peel the black tape away from the battery: 32 단계, 이미지 3개 중 3개
      • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
      • Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard.
      • Slide the spudger along the crevice to pry up the tape from the battery side.
      • Carefully peel the tape from the battery and fold it out of the way.
      댓글 쓰기
    3. Google Pixel 3 Motherboard Replacement, Disconnect the press connectors: 33 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Disconnect the press connectors: 33 단계, 이미지 2개 중 2개
      • Use a spudger to pry up and disconnect the following seven press-fit connectors from their motherboard sockets:
      • External buttons connector
      • Top microphone connector
      • Earpiece connector
      • Left squeeze sensor connector
      • Touchscreen (first picture) and OLED display (second picture) connectors
      • Right squeeze sensor connector
      • SIM tray connector
      댓글 쓰기
    4. Google Pixel 3 Motherboard Replacement, Move the earpiece speaker cable away from the motherboard: 34 단계, 이미지 1개 중 1개
      • Use the flat of a spudger to carefully pry up and bend the earpiece speaker's flex cable upwards, out of the way of the motherboard.
      댓글 쓰기
    5. Google Pixel 3 Motherboard Replacement, Remove the screws: 35 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the screws: 35 단계, 이미지 2개 중 2개
      • Some of these screws hold very small grounding clips in place. Be careful not to lose these clips as you remove the screws.
      • Remove the six screws securing the motherboard in place:
      • One 4.2 mm Phillips screw
      • Three 1.9 mm Phillips screws
      • One 4.3 mm Phillips screw
      • One 3.83 mm standoff screw
      • Remove and retain the three small metal grounding clips.
      댓글 쓰기
    6. Google Pixel 3 Motherboard Replacement, Remove the antenna bracket: 36 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the antenna bracket: 36 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Remove the antenna bracket: 36 단계, 이미지 3개 중 3개
      • Carefully remove the antenna bracket from the top left edge of the phone.
      • To reinstall the small metal grounding clips:
      • Orient the clips such that the silver side is facing upwards.
      • The teardrop shaped clips should have their points facing towards the phone edge.
      • The double-holed clip dips downwards towards the frame's top-right screw hole.
      댓글 쓰기
    7. Google Pixel 3 Motherboard Replacement, Check the motherboard: 37 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Check the motherboard: 37 단계, 이미지 2개 중 2개
      • Insert the point of a spudger near the top left corner of the motherboard, right below the rear-facing camera.
      • Pry up gently to loosen the motherboard, bending all flex cables away to accommodate for the movement.
      • If the motherboard feels firmly seated, check for any flex cables or screws that may still be connected.
      댓글 쓰기
    8. Google Pixel 3 Motherboard Replacement, Loosen the motherboard: 38 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Loosen the motherboard: 38 단계, 이미지 2개 중 2개
      • Insert the spudger underneath the top edge of the motherboard and carefully pry up to loosen the motherboard.
      • The earpiece speaker's flex cable will press tightly against the motherboard. Take your time and carefully guide the motherboard around the flex cable.
      댓글 쓰기
    9. Google Pixel 3 Motherboard Replacement, Start removing the motherboard: 39 단계, 이미지 2개 중 1개 Google Pixel 3 Motherboard Replacement, Start removing the motherboard: 39 단계, 이미지 2개 중 2개
      • Lift the left edge of the motherboard and carefully swing it upwards towards the right. Carefully push any press connectors snagging the motherboard out of the way.
      댓글 쓰기
    10. Google Pixel 3 Motherboard Replacement, Remove the motherboard: 40 단계, 이미지 3개 중 1개 Google Pixel 3 Motherboard Replacement, Remove the motherboard: 40 단계, 이미지 3개 중 2개 Google Pixel 3 Motherboard Replacement, Remove the motherboard: 40 단계, 이미지 3개 중 3개
      • Carefully lift the top end of the motherboard away from the frame.
      • Remove the motherboard.
      • When you reinstall the motherboard, be careful not to trap any flex cable connectors underneath it.
      • It may be difficult to reposition the motherboard around the earpiece flex cable. You can gently pry up the earpiece speaker, install the motherboard, and reinstall the earpiece speaker.
      댓글 쓰기
결론
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,189 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 32,283개를 작성함
7가이드 댓글
Hallo,
wo bekomme ich denn ein neues Mainboard her? Ich komme nicht mehr ins recovery und vermute Mainboarddefekt.
Helge - 답글 공유
I followed your instructions to the letter. Got it all put back together, but before affixing the back glass, I powered up the Pixel 3 to make sure all features are working. The touch screen does not work, now, but it did before. Any advice?
Philip Wickstrom - 답글 공유
Hi Philip,
Does the screen light up? If it doesn’t, I would suggest disconnecting the battery connector and double-checking the display connector to make sure it is properly seated. As I looked into your question, I noticed that the step was missing a disconnection procedure—so thank you! I’ve amended that step.
Arthur Shi - 답글 공유
Hi, I met the same issue as you, the touch didn't work after replacing the mother board. Do you know why? And have you fixed the problem?
notreally - 답글 공유
Where can I buy the motherboard? Is the 128 GB motherboard different from the 64 GB?
Orlando Terte - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 26
지난 30일: 130
전체 시간: 21,180
