주요 콘텐츠로 건너뛰기
Google Pixel 3 XL Battery Replacement
필요한 것
  1. Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: 1 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: 1 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Heat the edge of the back cover: 1 단계, 이미지 3개 중 3개
    • Heat an iOpener and apply it to the right edge of the back cover for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back cover:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: 2 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: 2 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Create a gap under the back cover: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: 3 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: 3 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Loosen the right edge adhesives: 3 단계, 이미지 3개 중 3개
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Google Pixel 3 XL Battery Replacement, Heat the bottom edge of the back cover: 4 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom of the back cover for a minute.
  5. Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: 5 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: 5 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Slice through the bottom adhesives: 5 단계, 이미지 3개 중 3개
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: 6 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: 6 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Slice through the remaining edges: 6 단계, 이미지 3개 중 3개
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
  7. Google Pixel 3 XL Battery Replacement, Slice through the leftover adhesive: 7 단계, 이미지 1개 중 1개
    • Gently pry up the right edge of the back cover.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Google Pixel 3 XL Battery Replacement, Swing open the back cover: 8 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Swing open the back cover: 8 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Swing open the back cover: 8 단계, 이미지 3개 중 3개
    • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
    • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
  9. Google Pixel 3 XL Battery Replacement, Remove the fingerprint sensor tape: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
  10. Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: 10 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: 10 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Disconnect the fingerprint sensor: 10 단계, 이미지 3개 중 3개
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Google Pixel 3 XL Battery Replacement, Remove the back cover: 11 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket screws: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Remove the following four T3 screws securing the metal cover bracket:
    • Three 4 mm long screws
    • One 3 mm long screw
  13. Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket: 13 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Remove the metal cover bracket: 13 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger underneath the top right edge of the metal bracket and pry up to loosen it.
    • Remove the metal cover bracket.
  14. Google Pixel 3 XL Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
    • Do not use metal tools to to disconnect the battery, or you will risk shorting the battery.
    • Bend the battery cable such that the connector will not accidentally touch the socket.
  15. Google Pixel 3 XL Battery Replacement, Disconnect the charging coil: 15 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Disconnect the charging coil: 15 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the charging coil connector from motherboard near the right edge of the phone.
  16. Google Pixel 3 XL Battery Replacement, Slice under the charging coil: 16 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Slice under the charging coil: 16 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Slice under the charging coil: 16 단계, 이미지 3개 중 3개
    • Insert the point of an opening pick underneath one edge of the charging coil.
    • Slide the pick along the edge to loosen the adhesive.
    • Slice as deep as you can while taking care not to puncture the battery's surface.
  17. Google Pixel 3 XL Battery Replacement, Apply adhesive remover under the coil: 17 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Apply adhesive remover under the coil: 17 단계, 이미지 2개 중 2개
    • Tilt the edge you have been slicing upwards.
    • While holding the phone in a tilted position, apply a few drops of adhesive remover or high concentration isopropyl alcohol along the edge.
    • Keep the phone in that position for a minute or two to allow the adhesive to soften.
  18. Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: 18 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: 18 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Slice through the coil adhesive: 18 단계, 이미지 3개 중 3개
    • Insert the flat end of an opening pick underneath a corner of the charging coil.
    • Push the pick slowly and firmly under the coil to loosen the adhesive.
    • The adhesive is mostly around the perimeter of the wireless coil. Use the opening pick to slowly slice through the adhesive.
    • If the adhesive feels difficult to slice through, tilt the phone up and apply a few more drops of adhesive remover.
  19. Google Pixel 3 XL Battery Replacement, Remove the charging coil: 19 단계, 이미지 1개 중 1개
    • Remove the wireless charging coil.
    • To install a replacement coil:
    • Be sure to clean off the battery surface of any adhesive residue. Be very careful not to puncture the battery.
    • Connect the wireless coil connector to its motherboard socket. This ensures that the coil is properly aligned.
    • Peel off any adhesive backing on the replacement coil.
    • Lay the coil on top of the battery and firmly press it into position.
  20. Google Pixel 3 XL Battery Replacement, Disconnect the button array connector: 20 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Disconnect the button array connector: 20 단계, 이미지 2개 중 2개
    • The next two steps show how to disconnect the button array connector so you won't accidentally damage it when you pry the battery out.
    • Remove the two 3 mm-long T3 screws securing the button array connector bracket.
    • Remove the button array connector bracket.
  21. Google Pixel 3 XL Battery Replacement: 21 단계, 이미지 1개 중 1개
    • Use the point of a spudger to pry up and disconnect the button array connector from its motherboard socket.
  22. Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: 22 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: 22 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Loosen the insulating tape: 22 단계, 이미지 3개 중 3개
    • Insert the point of a spudger into the gap along the top edge of the battery.
    • Slowly slide the point along the gap to lift up and detach the insulating tape from the battery.
    • Fold the tape away from the battery.
  23. Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: 23 단계, 이미지 3개 중 1개 Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: 23 단계, 이미지 3개 중 2개 Google Pixel 3 XL Battery Replacement, Loosen the battery pull tabs: 23 단계, 이미지 3개 중 3개
    • Carefully slide the point of a spudger underneath the yellow battery pull tabs folded along the top edge of the battery.
    • Separate the pull tabs from the battery.
  24. Google Pixel 3 XL Battery Replacement, Insert a bracing pick: 24 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Insert a bracing pick: 24 단계, 이미지 2개 중 2개
    • There are steep, sharp edges near the top of the battery, that can easily break the adhesive strip as it's being pulled out.
    • Insert the flat end of an opening pick into the gap above the battery, behind a yellow pull tab.
    • Wedge the pick firmly underneath the battery. The pick will serve as a buffer for the adhesive strip as well as a prying point.
  25. Google Pixel 3 XL Battery Replacement, Remove the battery adhesive strips: 25 단계, 이미지 2개 중 1개 Google Pixel 3 XL Battery Replacement, Remove the battery adhesive strips: 25 단계, 이미지 2개 중 2개
    • Pull on the yellow adhesive pull tab with slow steady force. Try your best to pull it as shallow of an angle (vs. straight up) as possible.
    • As you pull on the adhesive tab, maintain pressure on the opening pick to wedge it underneath the battery as much as possible.
    • If the adhesive feels stuck, you can apply a few drops of adhesive remover or high concentration isopropyl alcohol into the gap to help loosen the battery. Doing this will most likely loosen both strips at once.
    • Repeat the process with the second adhesive pull tab.
  26. Google Pixel 3 XL Battery Replacement, Remove the battery: 26 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a replacement battery:
    • Remove any remaining adhesive from the battery well.
    • Temporarily re-connect the battery connector to its motherboard socket. This ensures that the battery will be properly aligned.
    • Apply stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
    • Lay the battery in the phone and press it firmly in place.
    • Disconnect the battery connector from its motherboard socket and resume reassembly.
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 98명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,870 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,619개를 작성함
48가이드 댓글
Very helpful, thank you! I was able to replace my battery pretty easily thanks to this guide.
Gabriel Frederick - 답글
Hey. After installing ney battery and new usb port my Pixel 3 has problems with microphones. Its only works with phoning via speakers. can you help me ?
kevin reiter - 답글
Hi Kevin,
Assuming that you did not remove the motherboard (which houses a mic), it sounds like something may be off with the daughterboard, which surrounds the USB port and houses the other microphone. I would suggest carefully disconnecting and re-seating the daughterboard connectors, and making sure that the microphone is aligned to the port.
Arthur Shi -
Thanks for these great instructions.
I followed them, and managed to replace my old Pixel 3 XL battery without any problems.
Luis Ibanez - 답글
What about re attaching the charging coil? The adhesive is now shot on the coil. What should you do to adhere the coil to the new battery?
Glendon sowder - 답글
댓글 쓰기
조회 통계:
지난 24시간: 57
지난 7일: 511
지난 30일: 1,194
전체 시간: 78,388
