주요 콘텐츠로 건너뛰기
Google Pixel Watch Vibration Motor Replacement
필요한 것
  1. Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 1 단계, 이미지 3개 중 1개 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 1 단계, 이미지 3개 중 2개 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 1 단계, 이미지 3개 중 3개
    • Before starting repairs, turn off your watch and take it off the charger.
    • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
    • Repeat for the other watch band.
  2. Google Pixel Watch Vibration Motor Replacement, Loosen the screen adhesive: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  3. Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: 3 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFlex Opening Tool
    $11.99
    • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
    • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
  4. Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 3개
    • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
    • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
  5. Google Pixel Watch Vibration Motor Replacement, Pry up the screen: 5 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Pry up the screen: 5 단계, 이미지 2개 중 2개
    • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
    • Twist the iFlex to pry the screen up.
    • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
  6. Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 6 단계, 이미지 3개 중 1개 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 6 단계, 이미지 3개 중 2개 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 6 단계, 이미지 3개 중 3개
    • Be careful not to strain the screen assembly cable when you open the display.
    • Swing the screen open to an upright position.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
  7. Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: 7 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Torx T2 screwdriver to remove the 2.1 mm-long screw securing the speaker bracket.
  8. Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 1개 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 2개 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals or catch fire.
    • Use a pair of tweezers to remove the speaker bracket.
  9. Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: 9 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: 9 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the vibration motor‘s press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  10. Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: 10 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: 10 단계, 이미지 2개 중 2개
    • Be careful with sharp tools around the battery.
    • Use tweezers to peel up the yellow tape securing the vibration motor cable to the battery.
  11. Google Pixel Watch Vibration Motor Replacement, Unfasten the vibration motor: 11 단계, 이미지 1개 중 1개
    • Use a Torx T2 screwdriver to remove the two screws securing the vibration motor:
    • One 1.8 mm-long screw
    • One 2.8 mm-long screw
  12. Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 1개 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 2개 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 3개
    • Use tweezers to lift the grounding bracket out of its recess and remove it.
  13. Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: 13 단계, 이미지 2개 중 1개 Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: 13 단계, 이미지 2개 중 2개
    • Remove the vibration motor.
결론
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,305 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,738개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 50
전체 시간: 1,071
