주요 콘텐츠로 건너뛰기
HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement
Wilfredo Ramos
Wilfredo Ramos17 다른 기여자
최종 수정일 January 8, 2025
5 - 10 분
조정
The keyboard and touchpad of your HP Chromebook 14-Q010DX are essential for typing, scrolling, and navigating your laptop. If they are damaged or malfunctioning, you may want to replace them with a new part. The repair should take 5-10 minutes and this guide will help you to replace the Keyboard and touchpad and will show you how to open the laptop, disconnect the old part, and connect the new one. You will need a new keyboard, touchpad, a Phillips #00 screwdriver, a Spudger and an iFixit opening tool which can be found online.
필요한 것
부품
도구
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
더보기...
  1. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: 1 단계, 이미지 2개 중 2개
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
  2. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 4 단계, 이미지 1개 중 1개
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Set aside the detached keyboard.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
17다른 기여자 명과 함께
Wilfredo Ramos
회원 가입일: 01/28/15
621 평판
안내서 1개를 작성함
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G2
4 회원들
안내서 8개를 작성함
댓글 10개
In the black variant of this model I found that there are two screws under the rubber feet near the hinge.
Justin Cowen - 답글
Super easy repair, keep track of your screws and be very careful with ribbon that connects keyboard and Touch pad.
Terry - 답글
This was very close to a similar HP Chromebook I had to repair recently. Such a beautiful and simple process. I cleaned the keyboard connectors and everything functioned perfectly after I was done. The whole process took about 30 minutes (allotting 10 minutes to find my rubbing alcohol that my wife hid from me).
Josh Bollman - 답글
Any idea how to get the replacement keyboard?
Pawel Wozniak - 답글
At the top of this page under "Relevant parts" there is a link to purchase the keyboard replacement.
Kevin Piper -
Purchased a Chromebook like this one at a garage sale. The previous owner stated that several keys didn't work. I used this guide to dis-assemble and clean it, re-seated the keyboard connector and now it works perfectly. Thank you for this excellent guide.
Steven Sizelove - 답글
Very helpful! This was way easier than I thought it would be. I agree with Justin, though. I have a white/green model (14-x015wm model) and I had to remove the two rubber feet which are at the top of the image (closest to the screen) in order to remove two more screws.
Patrick Maguire - 답글
In my unit, the issue was with the keys directly over the CPU fan. The backing did not provide enough support when pressing the keys. I taped a support mesh plate behind the keyboard (held in place by electrical tape). Now, it seems to provide the necessary support that the plastic mesh could not.
btaira - 답글
I had a problem with certain chromebook keys not responding - pretty much all the ones around the 'h' key. I followed this guide, disconnected the keyboard connector and cleaned it with white spirit then reconnected. Hey presto I can now type words like hyugjmtnb and bjumgytun again with ease. Many thanks, I love my chromebook and this was my last resort before splashing out on a new machine :)
Ric Bar - 답글
is there a way to avoid my chromebook from turning on when i open it after unscrewing the screws from the underside? or do i have to wait until it dies?
Eugene Zabala - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 13
지난 30일: 21
전체 시간: 16,134
