주요 콘텐츠로 건너뛰기
HP Compaq 6730b Keyboard Replacement
oldturkey03
oldturkey03다른 한 명의 기여자
최종 수정일 December 16, 2013
5 - 10 분
쉬움
커뮤니티-기여 안내서
This is a straight forward removal of the keyboard. I needed to remove it to replace the LCD.
필요한 것
도구
  1. HP Compaq 6730b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Compaq 6730b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Compaq 6730b Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over.Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
  2. HP Compaq 6730b Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Compaq 6730b Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Compaq 6730b Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected
  3. HP Compaq 6730b Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. The keyboard is now separated and can now be removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
812,890 평판
안내서 119개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 2개
Old laptop, good modular design!
O Dumper - 답글
I moved back all 4 tabs and keyboard lifted from the right but not from the left. After multiple attempts to no avail I tried pressing the loose right back in hoping it would realign and lift at once but it snapped into position and wouldn’t move. I even removed all 4 tabs from their place to no avail. Somehow the keyboard is snapped in place without the tabs playing any part. I looked up a video on what to do and stumbled on this. Still no clue what I can do to free the keyboard.
Ben - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 6,733
