주요 콘텐츠로 건너뛰기
HP Pavilion 13-P110NR Battery Replacement
Matthew "Cole" Corson
Matthew "Cole" Corson3 다른 기여자
최종 수정일 August 1, 2019
20 - 25 분
조정
This guide provides a detail explanation of how to replace your device's battery. Before you begin, make sure you have adequately troubleshoot your poor battery life using this Troubleshooting Page. In addition, make sure you have read through all the steps required and understand what you will be doing. If you don't understand or feel comfortable completing any of the steps, find someone with more experience to assist you with this guide.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. HP Pavilion 13-P110NR Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Gently use the black nylon spudger to pry the back casing from the screen until it snaps apart.
  2. HP Pavilion 13-P110NR Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the gray latch back and remove the blue and white band of wires from the green motherboard.
  3. HP Pavilion 13-P110NR Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 13-P110NR Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 13-P110NR Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the black and white wire out of the green circuit board.
    • Pull the red and black wire out on the other side of the device.
  4. HP Pavilion 13-P110NR Battery Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the three screws from the circuit board using a Phillips #00 screwdriver.
    • Unscrew two 4.0 mm Philips #00 screws from the left side of the battery.
    • Unscrew two 3.0 mm Philips #00 screws from the right side of the battery.
  5. HP Pavilion 13-P110NR Battery Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the bound (red, white and black) wires connecting the battery and the motherboard.
  6. HP Pavilion 13-P110NR Battery Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the battery without pulling the copper information transmitter out.
결론
작성자
3다른 기여자 명과 함께
회원 가입일: 01/18/18
727 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 586
