소개
By following this guide, you will be able to change the RAM sticks on your laptop. You may wish to do this if you want to upgrade the maximum RAM available or if you are noticing slowdown on your computer. You will first remove the battery before you remove the RAM.
도구
부품
지정된 부품이 없습니다.
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
