주요 콘텐츠로 건너뛰기
HP Pavilion 17-ak008cy Speakers Replacement
Andrew Boardman
Andrew Boardman2 다른 기여자
최종 수정일 January 3, 2022
8 - 15 분
쉬움
액션 샷
더 나은 이미지가 필요함
더 많은 이미지가 필요함
더 나은 소개글
Overall there very little new cautions and hazards added to this guide. When looking at issues that may be caused by faulty or damaged speaker, is lack of sound or damaged wires. Accessing the speakers can only be accomplished after the prerequisites are met which are listed later on.
필요한 것
도구
  1. HP Pavilion 17-ak008cy Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Speakers Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 17-ak008cy Speakers Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 17-ak008cy Speakers Replacement: 2 단계, 이미지 3개 중 3개
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: 3 단계, 이미지 3개 중 1개 HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: 3 단계, 이미지 3개 중 2개 HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: 3 단계, 이미지 3개 중 3개
    • Remove eleven screws from the back panel.
    • Remove the optical drive from the side.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 1개 HP Pavilion 17-ak008cy Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 2개 HP Pavilion 17-ak008cy Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, remove the two screws (one on each speaker) securing the speakers to the motherboard.
  5. HP Pavilion 17-ak008cy Speakers Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 17-ak008cy Speakers Replacement: 5 단계, 이미지 2개 중 2개
    • Gently unplug the speaker connector from the motherboard.
  6. HP Pavilion 17-ak008cy Speakers Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 17-ak008cy Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully untangle the red wires tucked in between the black plastic tabs.
    • Remove the speakers from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrew Boardman
회원 가입일: 10/25/21
487 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G2
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 121
