주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6180us Motherboard Replacement
michelle pulido
michelle pulido8 다른 기여자
최종 수정일 July 1, 2020
1 시간
조정
If you are having complications with laptop having to boot and then shutting off, or blue screens of death, you may want to replace the motherboard.
필요한 것
부품
도구
더보기...
  1. HP Pavilion dv6-6180us Motherboard Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the hard drive wire to detach the hard drive.
    Don't forget to unplug 2 connectors next to the drive's connector. They're not mentioned anywhere in the guide but you won't remove the motherboard with them.
    Krzeszny - 답글
  7. HP Pavilion dv6-6180us Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Remove a 3.5 mm screw that is securing DVD player with screwdriver PH1.
  8. HP Pavilion dv6-6180us Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Slide DVD player to the left and pull to remove completely.
  9. HP Pavilion dv6-6180us Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  10. HP Pavilion dv6-6180us Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Flip side up and open laptop.
    • Pry open the keyboard using a plastic opening tool starting from the top.
    • Lift up keyboard gently because a silver ribbon is still attaching it to the laptop.
  11. HP Pavilion dv6-6180us Motherboard Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion dv6-6180us Motherboard Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion dv6-6180us Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard connector cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  12. HP Pavilion dv6-6180us Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  13. HP Pavilion dv6-6180us Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Place the computer on its side
    • Separate top panel from bottom frame.
  14. HP Pavilion dv6-6180us Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Pop open rest palm assembly.
  15. HP Pavilion dv6-6180us Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Pull ribbon to detach from bottom panel.
  16. HP Pavilion dv6-6180us Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove two 5mm screws securing fan, using PH1 screwdriver.
    You forgot about the screw that secures the motherboard on the bottom left. It's in the photo.
    Krzeszny - 답글
  17. HP Pavilion dv6-6180us Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Flip laptop over.
    • Remove two 4mm screws securing antenna using PH 1 screwdriver.
    • Pull antenna to the right to remove.
  18. HP Pavilion dv6-6180us Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Flip laptop side up.
    • Pull off yellow insulating tape.
  19. HP Pavilion dv6-6180us Motherboard Replacement: 19 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Grab tab on left top corner and remove black wire.
    • Remove white input attachment.
  20. HP Pavilion dv6-6180us Motherboard Replacement: 20 단계, 이미지 1개 중 1개
    • Hold the motherboard and pull to the right.
    • The plugs on the left may be difficult to snap out.
  21. HP Pavilion dv6-6180us Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Remove entire motherboard.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
michelle pulido
회원 가입일: 09/15/16
859 평판
안내서 4개를 작성함
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G2
4 회원들
안내서 4개를 작성함
댓글 5개
Great tutorial. Thanks!!!!
victor4pro - 답글
Nothing, thank you very much, it is a pleasure to help more people
Tomas - 답글
very Excellent tutorial …… Thank you
Hussein Knani - 답글
Excellent tutorial …. thank you
Hussein Knani - 답글
Tomas -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 38
전체 시간: 5,516
