주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1285dx Keyboard Replacement
Jesse Quisido
Jesse Quisido4 다른 기여자
최종 수정일 June 6, 2014
30 분
조정
액션 샷
더 나은 이미지가 필요함
This guide is made to assist a user in replacing an HP Pavilion dv7-1285dx keyboard.
필요한 것
부품
도구
더보기...
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 2개
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv7-1285dx Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv7-1285dx Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jesse Quisido
회원 가입일: 04/14/14
489 평판
안내서 3개를 작성함
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 회원
CPSU-MANESS-S14S12G34
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 3,885
