주요 콘텐츠로 건너뛰기
How to Fix Thread Tension on a Juki DDL-8700
Brandon Mammon
Brandon Mammon2 다른 기여자
최종 수정일 December 20, 2024
45 분
조정
This guide will fix the thread tension on a Juki DDL-8700 lockstitch industrial sewing machine.
When working on sewing projects, you often change the fabric and threads that you use. With this, the sewing machine tension must be adjusted before sewing. Without proper thread tension, loops and bundles of thread (bird nests) can be created, rendering the sewing machine almost unusable.
This guide will demonstrate how to fix thread tension issues, returning the machine to working order.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 3개
    • Thread the machine.
    • Insert the bobbin case.
  2. How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 3개
    • Sew a straight line on scrap fabric to test thread tension.
    • Be cautious when placing your fingers near the needle when working with the machine turned on.
  3. How to Fix Thread Tension on a Juki DDL-8700: 3 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 3 단계, 이미지 2개 중 2개
    • Check the fabric for loose thread tension.
    • Look out for loops of thread on the top and bottom of the fabric.
    • The bobbin case tension is too loose if loops are on the top of the fabric.
    • The upper thread tension is too loose if the loops are on the bottom of the fabric.
  4. How to Fix Thread Tension on a Juki DDL-8700: 4 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 4 단계, 이미지 2개 중 2개
    • Take out the bobbin case.
  5. How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 3개
    • Create a baseline thread tension for the bobbin case by tightening or loosening the screw on the bobbin case.
    • Thread should not easily unravel but can be pulled loosely.
  6. How to Fix Thread Tension on a Juki DDL-8700: 6 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 6 단계, 이미지 2개 중 2개
    • Reinsert the bobbin case into the machine.
  7. How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 3개
    • Sew another straight line on the scrap fabric next to the previous line.
  8. How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 3개
    • Check the front and back thread tension of the scrap fabric for loose stitches.
  9. How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 3개
    • Adjust the upper thread tension.
    • If there are loose stitches on the top of the fabric, loosen the upper thread tension by turning the tension knob counterclockwise.
    • If there are loose stitches on the bottom of the fabric, tighten the upper thread tension by turning the tension knob clockwise.
  10. How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 3개
    • Check the thread tension by sewing another straight line on the scrap fabric next to the previous line.
  11. How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 3개
    • The thread tension is correct if there are no loose stitches.
    • Repeat steps 5-8 as needed to achieve a consistent thread tension without loops on top or bottom of scrap fabric.
결승점
작성자
2다른 기여자 명과 함께
Brandon Mammon
회원 가입일: 11/05/24
193 평판
안내서 1개를 작성함
UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S1G9
2 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 57
전체 시간: 191
