주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix a Slipped Bicycle Chain
Keely Thompson
Keely Thompson3 다른 기여자
최종 수정일 2020년 5월 5일
30 초 - 15 분
쉬움
Slipped bike chains may be caused by several different problems including poor shifting technique, the chain being too long, or a worn out chain or rear casters.
필요한 것
부품
도구
더보기...
  1. How to Fix a Slipped Bicycle Chain, How to Fix a Slipped Bicycle Chain: 1 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain, How to Fix a Slipped Bicycle Chain: 1 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain, How to Fix a Slipped Bicycle Chain: 1 단계, 이미지 3개 중 3개
    • Before getting off the bike, downshift bike into lowest front gear (using the left shifter).
    • Being in the lowest front gear means the chain will be riding on the largest chain ring.
    • Continue pedaling. This step alone may realign the chain.
  2. How to Fix a Slipped Bicycle Chain: 2 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 2 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 2 단계, 이미지 3개 중 3개
    • If Step 1 did not work, get off the bike and lift the rear tire while spinning the pedals with your hand.
  3. How to Fix a Slipped Bicycle Chain: 3 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 3 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 3 단계, 이미지 3개 중 3개
    • If Step 2 is not enough, push rear derailleur forward to release tension on the chain.
    • Lift the chain and put it back on the chain ring.
    • Turn the pedals with your hand while lifting the rear wheel to realign the chain (as in Step 2).
    • Bike chains are very greasy and your hands will get messy. Use a pair of latex gloves, if available, or use a twig or leaf if you can.
    • This step may take several attempts, but it will work eventually.
  4. How to Fix a Slipped Bicycle Chain: 4 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 4 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 4 단계, 이미지 3개 중 3개
    • If you experience a lot of slipped chains, your chain might be too long. In this case, you will need to use a chain breaker.
    • Put the chain on the outer chain guide of the chain breaker.
    • Turn the handle on the chain breaker to push the chain pin part of the way out.
    • This step may take quite a bit of force so don't be afraid that you are going to break something if the pin seems stuck.
    • Do not push the pin all of the way out or else it will be nearly impossible to put back together.
  5. How to Fix a Slipped Bicycle Chain: 5 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 5 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 5 단계, 이미지 3개 중 3개
    • Remove the chain breaker by backing up the drive pin.
    • Pull the chain apart.
  6. How to Fix a Slipped Bicycle Chain: 6 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 6 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 6 단계, 이미지 3개 중 3개
    • Repeat Steps 4-5 to remove a link:
    • There are two parts to one link (one is narrow and one is wide). Both need to be removed for the chain to fit back together again.
  7. How to Fix a Slipped Bicycle Chain: 7 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 7 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 7 단계, 이미지 3개 중 3개
    • If the chain fell off the rear derailleur, it needs to be re-fed through the proper pulleys.
    • Feed the chain along the guide pulley (the highest of the two pulleys).
    • Thread the chain inside the derailleur cage in between the tension and guide pulley.
    • Thread the chain in front of the tab.
    • Then, thread the chain over the tension pulley.
  8. How to Fix a Slipped Bicycle Chain: 8 단계, 이미지 3개 중 1개 How to Fix a Slipped Bicycle Chain: 8 단계, 이미지 3개 중 2개 How to Fix a Slipped Bicycle Chain: 8 단계, 이미지 3개 중 3개
    • To rejoin the chain, align the open ends of the chain.
    • Put the chain on the outer guide of the chain breaker with the pin facing the driving pin.
    • Turn the driving pin until the pin is equally spaced in between the face plates like all of the other links.
  9. How to Fix a Slipped Bicycle Chain: 9 단계, 이미지 2개 중 1개 How to Fix a Slipped Bicycle Chain: 9 단계, 이미지 2개 중 2개
    • Wiggle the link you just reattached. If it's too stiff, continue on to the next part.
    • Put the chain on the inside guide of the chain breaker and turn the driving pin just a little. Check as you go along and continue until proper looseness is achieved.
    • As before, do not push the pin all the way out.
결론
If your chain continues to slip, the chain or cogs are probably worn out. Have a local mechanic look at your bike and determine which needs to be replaced. If it's the chain, visit this guide <Triace A310 Chain Replacement>
다른 22명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
3다른 기여자 명과 함께
Keely Thompson
회원 가입일: 02/24/15
847 평판
안내서 1개를 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개를 작성함
7가이드 댓글
A guide to indicators if cogs are worn would have also been helpful. Many of us ride a bike due to financial constraints, employing local mechanic may not be possible (I certainly can't afford that). A brilliant guide otherwise, thank you.
evocrim - 답글
Thank you so much for this article--so many helpful tips here. But, I just saw this post ("Over 200 Bike Repair Videos and Hundreds of Pages of Illustrated Guides") and actually was reading about this same topic the other day. I did some searching around and stumbled onto this cool article… I thought it was helpful… http://diybikerepairguide.weebly.com
Tyrone Robinson - 답글
Thanks for the information. How do I know how long the new chain should be. Hint, don't have broken one.
Kenneth Silvestri - 답글
Thanks for your post. A bicycle normally drops off a gear or chain ring as the teeth have worn and become narrow.The chain has a bad link and stretched. To increase complexity, you have lots of options to ensure the dropped chain. You may like this too- http://www.mybiked.com/rechain-bike-usef...
Harry Bauman - 답글
I have a chain guide on my bike only now that the chain is off, I can’t seem to lift the chain onto the top of the chain ring as the guide is blocking this.
judith brough - 답글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 65
지난 30일: 341
전체 시간: 198,926
