주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reinstall the iFixit Digital Multimeter Outer Cover
  1. How to Reinstall the iFixit Digital Multimeter Outer Cover, Install the outer cover: 1 단계, 이미지 2개 중 1개 How to Reinstall the iFixit Digital Multimeter Outer Cover, Install the outer cover: 1 단계, 이미지 2개 중 2개
    • Firmly push the top edge of the multimeter into the cover's top cutout.
    • Try to get the top edge well aligned and seated. This will give you enough room to pull the cover's bottom edge in place.
    댓글 쓰기
  2. How to Reinstall the iFixit Digital Multimeter Outer Cover: 2 단계, 이미지 3개 중 1개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 2 단계, 이미지 3개 중 2개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 2 단계, 이미지 3개 중 3개
    • Flip the multimeter over.
    • The cover has a lip that needs to seat into the groove around the multimeter's kickstand.
    • Align and press the cover lip into the groove above the kickstand.
    댓글 쓰기
  3. How to Reinstall the iFixit Digital Multimeter Outer Cover: 3 단계, 이미지 3개 중 1개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 3 단계, 이미지 3개 중 2개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 3 단계, 이미지 3개 중 3개
    • Lift and tuck the cover lip into the groove near the top right corner of the kickstand.
    • Repeat the procedure for the top left corner of the kickstand.
    댓글 쓰기
  4. How to Reinstall the iFixit Digital Multimeter Outer Cover: 4 단계, 이미지 2개 중 1개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 4 단계, 이미지 2개 중 2개
    • Guide and press the cover lip into the grooves along the sides of the kickstand.
    • Pull the cover over the bottom edge of the multimeter and press the bottom lip into the groove under the kickstand.
    • Carefully check to make sure the cover lip sits completely in the groove around the kickstand.
    댓글 쓰기
  5. How to Reinstall the iFixit Digital Multimeter Outer Cover: 5 단계, 이미지 3개 중 1개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 5 단계, 이미지 3개 중 2개 How to Reinstall the iFixit Digital Multimeter Outer Cover: 5 단계, 이미지 3개 중 3개
    • Flip the multimeter over so that the front is facing up.
    • Squeeze the cover along the right edge to pop the cover lip into the groove along the side of the multimeter.
    • Repeat the process along the left edge of the multimeter.
    • Carefully check to make sure the cover is properly seated along the perimeter of the multimeter.
    댓글 쓰기
결론
For more information on how to use your iFixit multimeter, check out this page.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
343,721 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,236개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 197
