주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to join two wires with solder
필요한 것
    1. How to join two wires with solder, How to join two wires with solder: 1 단계, 이미지 1개 중 1개
      • Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
      • Make sure the wires' stripped ends are facing each other or are towards the center of the workplace. If not, orientate the wires accordingly.
      댓글 쓰기
    2. How to join two wires with solder: 2 단계, 이미지 2개 중 1개 How to join two wires with solder: 2 단계, 이미지 2개 중 2개
      • Using both stripped wire ends, wrap and tie both of the ends together.
      댓글 쓰기
    3. How to join two wires with solder: 3 단계, 이미지 1개 중 1개
      • Solder the tied ends of the filament.
      • Ensure to solder the connection completely, not just one area.
      • Try not to put too much solder on the connection, as it will add more resistance.
      댓글 쓰기
    4. How to join two wires with solder: 4 단계, 이미지 1개 중 1개
      • Pull on the two wires firmly to ensure the solder does not separate.
      댓글 쓰기
    5. How to join two wires with solder: 5 단계, 이미지 2개 중 1개 How to join two wires with solder: 5 단계, 이미지 2개 중 2개
      • To properly protect the soldered wire connection, use heat shrink.
      • Cut enough heat shrink to cover the soldered connection.
      • Slip the heat shrink onto the connection.
      • Using a heat generator, such as a heat gun or a hairdryer, heat the heat shrink around all of the angles until it securely covers the soldered connection.
      댓글 쓰기
결론
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joeny Zhen
회원 가입일: 02/24/15
427 평판
안내서 1개를 작성함
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 회원
CPSU-GREEN-W15S23G1
4 회원들
안내서 5개를 작성함
1가이드 댓글
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
Nathaniel Loeblein - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 50
전체 시간: 4,495
