주요 콘텐츠로 건너뛰기
Huawei Mate 10 Pro Daughterboard Replacement
Annabelle Harding
Annabelle Harding2 다른 기여자
최종 수정일 March 8, 2023
15 - 45 분
조정
더 나은 이미지가 필요함
This guide will show how to access and remove the daughterboard of this device.
필요한 것
도구
더보기...
  1. Huawei Mate 10 Pro Daughterboard Replacement, SIM Card Tray: 1 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement, SIM Card Tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Daughterboard Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Daughterboard Replacement: 3 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement: 3 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Daughterboard Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Daughterboard Replacement: 4 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement: 4 단계, 이미지 2개 중 2개
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Daughterboard Replacement: 5 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  6. Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: 6 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: 6 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: 6 단계, 이미지 3개 중 3개
    • Unscrew the back cover from the base, then remove black cover.
    • Screws can be placed on a magnetic board to reduce chance of being lost.
  7. Huawei Mate 10 Pro Daughterboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unhook black strip over battery at both ends and remove.
  8. Huawei Mate 10 Pro Daughterboard Replacement: 8 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Daughterboard Replacement: 8 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Daughterboard Replacement: 8 단계, 이미지 3개 중 3개
    • Pop out daughterboard and disconnect black and white wires.
결론
작성자
2다른 기여자 명과 함께
Annabelle Harding
회원 가입일: 03/31/22
433 평판
안내서 3개를 작성함
IUPUI, Team 3-5, Harley Spring 2022 IUPUI, Team 3-5, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G5
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 18
전체 시간: 595
