주요 콘텐츠로 건너뛰기
Huawei P10 Lite Motherboard Replacement
필요한 것
  1. Huawei P10 Lite Motherboard Replacement, Back cover: 1 단계, 이미지 1/3 Huawei P10 Lite Motherboard Replacement, Back cover: 1 단계, 이미지 2/3 Huawei P10 Lite Motherboard Replacement, Back cover: 1 단계, 이미지 3/3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Motherboard Replacement: 2 단계, 이미지 1/3 Huawei P10 Lite Motherboard Replacement: 2 단계, 이미지 2/3 Huawei P10 Lite Motherboard Replacement: 2 단계, 이미지 3/3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Motherboard Replacement: 3 단계, 이미지 1/2 Huawei P10 Lite Motherboard Replacement: 3 단계, 이미지 2/2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Motherboard Replacement: 4 단계, 이미지 1/2 Huawei P10 Lite Motherboard Replacement: 4 단계, 이미지 2/2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Motherboard Replacement, SIM Card Tray: 5 단계, 이미지 1/2 Huawei P10 Lite Motherboard Replacement, SIM Card Tray: 5 단계, 이미지 2/2
    • Use a SIM card removal bit or tool and push it into the small hole in the SIM card tray.
    • Remove the SIM card tray.
  6. Huawei P10 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Huawei P10 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Huawei P10 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the three Phillips #000 screws.
    • Use tweezers to remove the two metal shields which cover the flex cables on the mainboard.
  7. Huawei P10 Lite Motherboard Replacement: 7 단계, 이미지 1/3 Huawei P10 Lite Motherboard Replacement: 7 단계, 이미지 2/3 Huawei P10 Lite Motherboard Replacement: 7 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the volume and power button, the display and the main flex cable.
  8. Huawei P10 Lite Motherboard Replacement: 8 단계, 이미지 1/2 Huawei P10 Lite Motherboard Replacement: 8 단계, 이미지 2/2
    • Disconnect the battery flex cable with a spudger.
    • Unplug the antenna cable with tweezers.
  9. Huawei P10 Lite Motherboard Replacement: 9 단계, 이미지 1/3 Huawei P10 Lite Motherboard Replacement: 9 단계, 이미지 2/3 Huawei P10 Lite Motherboard Replacement: 9 단계, 이미지 3/3
    • Disconnect the headphone jack flex cable with the flat end of a spudger.
    • Use an opening pick to pry out the motherboard until you can get a good grip.
    • Both camera are still attached to the motherboard. Don't damage them while you remove it.
    • Remove the motherboard.
    • If you want to replace your motherboard you need to disconnect both cameras and transfer them to your spare part.
    • On the back of the motherboard there are thermal pads (pink rubber-like gobs) for heat dissipation. If these thermal pads broke or are too dried out you might need to apply new thermal pads on the new display assembly or the motherboard.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 8명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,362 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
ma la scheda di ricambio dove la trovo?
ghisle84 - 답글
I need huawei p10 lite board 4gb 64gb
Fani Malik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 54
전체 시간: 13,090
