주요 콘텐츠로 건너뛰기
Huawei P10 Plus Front Facing Camera Replacement
필요한 것
  1. Huawei P10 Plus Front Facing Camera Replacement, Display: 1 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement, Display: 1 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement, Display: 1 단계, 이미지 3개 중 3개
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Front Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Front Facing Camera Replacement, Unfasten the screw: 3 단계, 이미지 1개 중 1개
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Front Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  5. Huawei P10 Plus Front Facing Camera Replacement, Midframe: 5 단계, 이미지 2개 중 1개 Huawei P10 Plus Front Facing Camera Replacement, Midframe: 5 단계, 이미지 2개 중 2개
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
  6. Huawei P10 Plus Front Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  7. Huawei P10 Plus Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  8. Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: 8 단계, 이미지 3개 중 1개 Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: 8 단계, 이미지 3개 중 2개 Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: 8 단계, 이미지 3개 중 3개
    • Peel of the adhesive tape that connects the front facing camera to the mainboard.
    • Use a spudger to disconnect the front camera flex cable.
    • Remove the front camera.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,693 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 1,103
