주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P20 Rear Glass Replacement
필요한 것
    1. Huawei P20 Rear Glass Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      댓글 쓰기
    2. Huawei P20 Rear Glass Replacement: 2 단계, 이미지 3개 중 1개 Huawei P20 Rear Glass Replacement: 2 단계, 이미지 3개 중 2개 Huawei P20 Rear Glass Replacement: 2 단계, 이미지 3개 중 3개
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      댓글 쓰기
    3. Huawei P20 Rear Glass Replacement: 3 단계, 이미지 2개 중 1개 Huawei P20 Rear Glass Replacement: 3 단계, 이미지 2개 중 2개
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      댓글 쓰기
    4. Huawei P20 Rear Glass Replacement: 4 단계, 이미지 3개 중 1개 Huawei P20 Rear Glass Replacement: 4 단계, 이미지 3개 중 2개 Huawei P20 Rear Glass Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a third opening pick at the bottom left corner.
      • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      댓글 쓰기
    5. Huawei P20 Rear Glass Replacement: 5 단계, 이미지 2개 중 1개 Huawei P20 Rear Glass Replacement: 5 단계, 이미지 2개 중 2개
      • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      댓글 쓰기
    6. Huawei P20 Rear Glass Replacement: 6 단계, 이미지 2개 중 1개 Huawei P20 Rear Glass Replacement: 6 단계, 이미지 2개 중 2개
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      댓글 쓰기
    7. Huawei P20 Rear Glass Replacement: 7 단계, 이미지 2개 중 1개 Huawei P20 Rear Glass Replacement: 7 단계, 이미지 2개 중 2개
      • Lift and remove the back cover.
      • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      댓글 쓰기
결론
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
262,140 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 37,814개를 작성함
3가이드 댓글
Hi Dominic, nice guide
Nicu Gherghin - 답글 공유
What size of adhesive should be used?
Jimmi Rasmussen - 답글 공유
Bonjour, j'ai un nappe qui était sur l'ancienne vitre arrière et je ne la vois pas dans ce tuto 😅
Je tâcher de tout bien remettre en place mais j'aimerais bien comprendre à quoi elle sert.
Merci d'avance et bravo pour votre travail, vous êtes géniaux 👍
cyp cabs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 59
전체 시간: 5,359
