주요 콘텐츠로 건너뛰기
Huawei P8 Display with Frame Replacement
필요한 것
  1. Huawei P8 Display with Frame Replacement, Huawei P8 Battery Replacement: 1 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement, Huawei P8 Battery Replacement: 1 단계, 이미지 2개 중 2개
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
  2. Huawei P8 Display with Frame Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two Torx T2 screws located at the bottom next to the device's Micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shards and get a better grip to open the phone.
  3. Huawei P8 Display with Frame Replacement: 3 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 3 단계, 이미지 2개 중 2개
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
  4. Huawei P8 Display with Frame Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two Phillips #00 screws that secure the front camera and display/battery connector brackets
  5. Huawei P8 Display with Frame Replacement: 5 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 5 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 5 단계, 이미지 3개 중 3개
    • Use a tweezer to remove the bracket covering the display and the battery flex connector.
    • Unplug the battery flex connector with a Spudger.
    • Remove the bracket covering the flex connector of the front camera.
  6. Huawei P8 Display with Frame Replacement: 6 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 6 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
  7. Huawei P8 Display with Frame Replacement: 7 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the power/volume cable and fold it out of the way.
    • Remove the liquid contact indicator.
  8. Huawei P8 Display with Frame Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the five Phillips #00 screws that hold down the motherboard of your Huawei P8.
  9. Huawei P8 Display with Frame Replacement: 9 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug the vibration motor flex connector.
    • Disconnect the antenna cable.
  10. Huawei P8 Display with Frame Replacement: 10 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 10 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 10 단계, 이미지 3개 중 3개
    • Unplug the display flex connector from the main board with a Spudger.
    • Disconnect and remove the antenna cable with a tweezer.
  11. Huawei P8 Display with Frame Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard from the phone.
  12. Huawei P8 Display with Frame Replacement: 12 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully peel up the flex cable of your loudspeaker.
    • If the cable is difficult to peel, heat the loudspeaker assembly with an iOpener or a heat gun.
    • Lift up the loudspeaker assembly with a spudger and remove it.
  13. Huawei P8 Display with Frame Replacement: 13 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 13 단계, 이미지 2개 중 2개
    • Free the end of the first adhesive pull tab to get a good grip on it.
    • Pull the adhesive tab in a slow constant movement to free the battery.
  14. Huawei P8 Display with Frame Replacement: 14 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 14 단계, 이미지 2개 중 2개
    • Free the end of the second adhesive pull tab.
    • Pull the adhesive tab in a slow constant movement.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
  15. Huawei P8 Display with Frame Replacement: 15 단계, 이미지 2개 중 1개 Huawei P8 Display with Frame Replacement: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
  16. Huawei P8 Display with Frame Replacement, Display with Frame: 16 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement, Display with Frame: 16 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement, Display with Frame: 16 단계, 이미지 3개 중 3개
    • Remove the vibration motor gasket.
    • Remove the vibration motor.
    • There is some adhesive under the vibration motor and its gasket. If you are not able to remove them, use an iOpener to loosen the adhesive a little bit.
  17. Huawei P8 Display with Frame Replacement: 17 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 17 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 17 단계, 이미지 3개 중 3개
    • Remove the power and volume button flex cable.
    • Remove the four Phillips #00 screws.
    • Use a tweezer to remove the plastic bracket which is covering the corner of the headphone jack.
  18. Huawei P8 Display with Frame Replacement: 18 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 18 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 18 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the headphone jack flex cable.
    • Use a tweezer to remove the first daughter board which was connected to the headphone jack.
    • Remove the second daughter board including the headphone jack.
    • Both daughterboards are clamped into the mid frame and a little bit tricky to remove. Try to grab them near the holes for the Phillips #00 screws to not damage any contacts.
  19. Huawei P8 Display with Frame Replacement: 19 단계, 이미지 3개 중 1개 Huawei P8 Display with Frame Replacement: 19 단계, 이미지 3개 중 2개 Huawei P8 Display with Frame Replacement: 19 단계, 이미지 3개 중 3개
    • Remove the gasket which was placed under the daughterboard in the top right corner of your phone.
    • Remove the earpiece speaker with a tweezer. Take care of its connectors while doing so.
    • Remove the front camera gasket.
  20. Huawei P8 Display with Frame Replacement: 20 단계, 이미지 1개 중 1개
    • Before reassembly compare your new replacement part with the old one and check for any additional components that might need to be transferred.
결론
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary and transfer the rubber gaskets and sealings of your old frame to the new one.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,064 평판
안내서 682개를 작성함
iFixit EU Team iFixit EU Team 회원
Staff
37 회원들
안내서 1,205개를 작성함
2가이드 댓글
Cracking guide, although mentioning the need to removed the stuck down power and volume buttons could be a great addition.
Michael McDaid - 답글
Hi,
aftet a quiet small shock this phone just stopped calling. everything works includind sms data and wifi, but no call.
could it be fixed by antenna replacement?
thanks !
friton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 40
전체 시간: 7,441
