소개
Use this guide to remove and replace the complete display with the frame of a Huawei P8.
필요한 것
First switch off your phone.
Remove the trays for the SD card and the SIM card.
Remove the two Torx T2 screws located at the bottom next to the device's Micro USB port.
Torx 2 also works :)
Tried pentalobe drivers but had to get a Torx 2 in the end, possibly some variation across regional models.
Pentalobe screws on my p8…
In the kit,i have only T2…
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary and transfer the rubber gaskets and sealings of your old frame to the new one.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
Cracking guide, although mentioning the need to removed the stuck down power and volume buttons could be a great addition.
