주요 콘텐츠로 건너뛰기
IBM ThinkPad T30 Fan Assembly Replacement
Alex Kost
Alex Kost9 다른 기여자
최종 수정일 February 20, 2025
30 - 45 분
조정
학생이 작성 중
누락된 단계
Use this guide to replace your fan and heat sink assembly.
필요한 것
도구
더보기...
  1. IBM ThinkPad T30 Fan Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 IBM ThinkPad T30 Fan Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: 2 단계, 이미지 2개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: 2 단계, 이미지 2개 중 2개
    • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
    • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
    • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
  3. IBM ThinkPad T30 Fan Assembly Replacement: 3 단계, 이미지 3개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement: 3 단계, 이미지 3개 중 2개 IBM ThinkPad T30 Fan Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
    • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
    • Use the plastic opening tool to gently pry the connector up from the motherboard.
    • You can now safely remove the keyboard.
  4. IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: 4 단계, 이미지 2개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: 4 단계, 이미지 2개 중 2개
    • Remove the three 4 mm Phillips #0 screws securing the fan assembly.
  5. IBM ThinkPad T30 Fan Assembly Replacement: 5 단계, 이미지 2개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pry the heat sink assembly upwards.
    • Be sure to reapply thermal compound on the processor and the heat sink when reassembling the device.
    • Be aware that there still is a wire attached to the fan that is connected to the motherboard upon removal.
    Thermal compound should always be a thin layer, just enough to make up for surface roughness of the two sides.
    l zeitlin - 답글
  6. IBM ThinkPad T30 Fan Assembly Replacement: 6 단계, 이미지 2개 중 1개 IBM ThinkPad T30 Fan Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
    • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
    • Warning—the stuff is hard to clean off clothing.
    • Follow iFixit's guide for [잘못된 안내서 링크] for a detailed explanation.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Alex Kost
회원 가입일: 10/05/12
271 평판
안내서 5개를 작성함
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G20
3 회원들
안내서 16개를 작성함
댓글 3개
There are two screws for keyboard removal! Almost snapped the keyboard in half trying to pry it off
Dima - 답글
Excellent instructions and very easy to follow (thanks for the pictures, they helped a lot!) Took me more than half an hour, but then I was trying to shove the teeny tiny white fan connector thing into the slot backwards..(my bad).. there is not a lot of room to maneuver in there. My ancient computer is working again and that makes me very happy, so thanks!
ML Hinrich - 답글
Really excellent instructions. Thank You for Your help!! Rolf Frey, Lucerne, Switzerland
Rolf Frey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 4,888
