주요 콘텐츠로 건너뛰기
JBL Flip 5 Battery Replacement
필요한 것
  1. JBL Flip 5 Battery Replacement, Pry up the fabric cover: 1 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Pry up the fabric cover: 1 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Pry up the fabric cover: 1 단계, 이미지 3/3
    • Before starting repairs, turn off your device and unplug any cables.
    • The fabric cover of the JBL Flip 5 is secured by plastic clips.
    • Insert the flat end of a spudger underneath a corner of the fabric cover.
    • Pry up to release the plastic clips securing the fabric cover.
  2. JBL Flip 5 Battery Replacement, Release the plastic clips: 2 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Release the plastic clips: 2 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Release the plastic clips: 2 단계, 이미지 3/3
    • Slide the spudger along the edge of the fabric cover while prying up to continue to separate the plastic clips.
  3. JBL Flip 5 Battery Replacement, Loosen the fabric cover edge: 3 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Loosen the fabric cover edge: 3 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Loosen the fabric cover edge: 3 단계, 이미지 3/3
    • Release the remaining plastic clips to fully separate the fabric cover.
  4. JBL Flip 5 Battery Replacement, Release the plastic clips: 4 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Release the plastic clips: 4 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Release the plastic clips: 4 단계, 이미지 3/3
    • Repeat the previous steps to release the plastic clips and to fully separate the opposite edge of the fabric cover.
  5. JBL Flip 5 Battery Replacement, Remove the fabric cover: 5 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Remove the fabric cover: 5 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Remove the fabric cover: 5 단계, 이미지 3/3
    • Use one hand to spread the edges of the fabric cover apart and your other hand to pull the speaker assembly away from the cover.
    • Remove the fabric cover.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
  6. JBL Flip 5 Battery Replacement, Unfasten the passive radiator bracket: 6 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Unfasten the passive radiator bracket: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 17 mm-long screws securing the passive radiator brackets.
  7. JBL Flip 5 Battery Replacement, Remove the passive radiator bracket: 7 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Remove the passive radiator bracket: 7 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Remove the passive radiator bracket: 7 단계, 이미지 3/3
    • The passive radiator bracket is held in place by mild adhesive around its center. If you‘re having trouble removing it, you can prepare an iOpener and apply it to the bracket for one minute to soften the adhesive.
    • Peel the passive radiator bracket off of the speaker assembly and remove it.
  8. JBL Flip 5 Battery Replacement, Unclip the left passive radiator: 8 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Unclip the left passive radiator: 8 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Unclip the left passive radiator: 8 단계, 이미지 3/3
    • The passive radiators are secured by plastic clips.
    • Insert an opening pick into the cutout next to the left passive radiator housing.
    • Push the opening pick underneath the passive radiator housing.
    • Pry upwards to release the plastic clip securing the passive radiator.
  9. JBL Flip 5 Battery Replacement: 9 단계, 이미지 1/3 JBL Flip 5 Battery Replacement: 9 단계, 이미지 2/3 JBL Flip 5 Battery Replacement: 9 단계, 이미지 3/3
    • Repeat the prying procedure for the three remaining plastic clips securing the left passive radiator.
  10. JBL Flip 5 Battery Replacement, Remove the left passive radiator: 10 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Remove the left passive radiator: 10 단계, 이미지 2/2
    • Remove the left passive radiator.
  11. JBL Flip 5 Battery Replacement, Unclip the right passive radiator: 11 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Unclip the right passive radiator: 11 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Unclip the right passive radiator: 11 단계, 이미지 3/3
    • Repeat the prying procedure for the four plastic clips securing the right passive radiator.
  12. JBL Flip 5 Battery Replacement, Remove the right passive radiator: 12 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Remove the right passive radiator: 12 단계, 이미지 2/2
    • Remove the right passive radiator.
  13. JBL Flip 5 Battery Replacement, Unfasten the woofer: 13 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the four 9.6 mm-long screws securing the woofer.
  14. JBL Flip 5 Battery Replacement, Move the woofer: 14 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Move the woofer: 14 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Move the woofer: 14 단계, 이미지 3/3
    • Don't try to remove the woofer all the way yet, as it‘s still connected to the motherboard.
    • The woofer cables are long enough allowing you to place the woofer outside the speaker assembly, but avoid straining or sharply folding the cables when you lift the woofer out of its recess.
    • Lift the woofer out of its recess and place it next to the speaker assembly.
  15. JBL Flip 5 Battery Replacement, Disconnect the woofer: 15 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Disconnect the woofer: 15 단계, 이미지 2/2
    • Use the tip of a spudger to push the woofer JST connector straight out of its socket to disconnect it.
  16. JBL Flip 5 Battery Replacement, Remove the woofer: 16 단계, 이미지 1/1
    • Remove the woofer.
  17. JBL Flip 5 Battery Replacement, Unlatch the power button cable ZIF connector: 17 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Unlatch the power button cable ZIF connector: 17 단계, 이미지 2/2
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the power button cable's ZIF connector.
  18. JBL Flip 5 Battery Replacement, Disconnect the power button cable: 18 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Disconnect the power button cable: 18 단계, 이미지 2/2
    • Use a pair of blunt nose tweezers to pull the power button cable straight out of the ZIF connector.
  19. JBL Flip 5 Battery Replacement, Disconnect the volume button cable: 19 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Disconnect the volume button cable: 19 단계, 이미지 2/2
    • Use a pair of blunt nose tweezers to pull the volume button cable straight out of its connector to disconnect it.
  20. JBL Flip 5 Battery Replacement, Disconnect the charging cable: 20 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Disconnect the charging cable: 20 단계, 이미지 2/2
    • Use a spudger to push the charging cable connector straight out of its socket and disconnect it.
  21. JBL Flip 5 Battery Replacement, Detach the power button cable: 21 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Detach the power button cable: 21 단계, 이미지 2/2
    • The power button cable is lightly adhered to the motherboard with tape.
    • Use a pair of blunt nose tweezers to peel the fabric tape securing the power button cable off the motherboard‘s edge.
  22. JBL Flip 5 Battery Replacement, Move the motherboard: 22 단계, 이미지 1/2 JBL Flip 5 Battery Replacement, Move the motherboard: 22 단계, 이미지 2/2
    • The antenna cable is still connected to the motherboard, and the volume button cable is adhered to the speaker housing. Avoid straining or tearing them in the following step.
    • Push the motherboard out of the speaker assembly until you get free access to the battery connector.
  23. JBL Flip 5 Battery Replacement, Disconnect the battery: 23 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Disconnect the battery: 23 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Disconnect the battery: 23 단계, 이미지 3/3
    • Squeeze the tab against the power cable connector, and pull the connector straight up from its socket to disconnect the battery.
  24. JBL Flip 5 Battery Replacement, Remove the battery: 24 단계, 이미지 1/3 JBL Flip 5 Battery Replacement, Remove the battery: 24 단계, 이미지 2/3 JBL Flip 5 Battery Replacement, Remove the battery: 24 단계, 이미지 3/3
    • Pull the battery out of the speaker assembly and remove it.
결론
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,050 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,198개 작성하였습니다
댓글 한 개
Excellent instructions! Nice clean photos. I had no problem at all getting the new battery put in. Well done!
Timmy Langdon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 110
30일 전: 593
전체 시간: 5,929
