주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Go 4 Battery Replacement
필요한 것
    1. JBL Go 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 JBL Go 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 JBL Go 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
      • Slide the tool along the edge of the housing until the grille releases.
      • Remove the grille.
      • Be sure that the battery has been drained completely before attempting this replacement.
      댓글 쓰기
    2. JBL Go 4 Battery Replacement: 2 단계, 이미지 3개 중 1개 JBL Go 4 Battery Replacement: 2 단계, 이미지 3개 중 2개 JBL Go 4 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Insert an opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      댓글 쓰기
    3. JBL Go 4 Battery Replacement: 3 단계, 이미지 2개 중 1개 JBL Go 4 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Find the connection between the motherboard and the battery cable as labeled.
      • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
      • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
      댓글 쓰기
    4. JBL Go 4 Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Go 4 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
      • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
      • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
      댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jackosn Caron
회원 가입일: 03/20/25
255 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 회원
UMASSD-KONN-S25S4G1
4 회원들
안내서 18개를 작성함
2가이드 댓글
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - 답글 공유
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 31
지난 30일: 138
전체 시간: 1,589
