주요 콘텐츠로 건너뛰기
LG V50 ThinQ Speaker & Charging Port Replacement
William Martin
William Martin3 다른 기여자
최종 수정일 May 7, 2024
20 - 45 분
조정
If your audio quality is much worse than it used to be, you may need to replace your speaker system! The most common cause of poor speaker performance is because of water damage over time.
If your charger port is no longer working, it could be because of dirt clogged within the speaker. Try to clean the port and see if it works before replacing the entire port.
Before using this guide, make sure to review the LG V50 ThinQ troubleshooting page to ensure there are no other options to save your speakers or charging port.
If the speaker system or charger port needs to be replaced, this guide will help you replace them for your LG V50 ThinQ android phone. Make sure the device is powered off before replacing any parts.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 1 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 1 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 1 단계, 이미지 3개 중 3개
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Speaker & Charging Port Replacement: 2 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement: 2 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    • With the back side open, remove all 12 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Speaker & Charging Port Replacement: 3 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement: 3 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two brackets that are covering internal components.
  4. LG V50 ThinQ Speaker & Charging Port Replacement: 4 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement: 4 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Disconnect the orange cable by pulling the connector up with your fingers.
    • Pull up with tweezers on the end of the white wire to disconnect it from the two circuit boards.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Speaker & Charging Port Replacement: 5 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement: 5 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Take out the SIM card by using the SIM head and pushing into the SIM ejector slot.
    • Disconnect the orange panel nearby the SIM slot from the circuit board.
    • Pull up from below the circuit board on the top, next to the CMOS battery to remove the upper circuiting from the phone.
  6. LG V50 ThinQ Speaker & Charging Port Replacement: 6 단계, 이미지 3개 중 1개 LG V50 ThinQ Speaker & Charging Port Replacement: 6 단계, 이미지 3개 중 2개 LG V50 ThinQ Speaker & Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • Pull up from the right of the metallic cover piece inside of the bottom right of the phone.
    • Remove the metallic piece's base from the board.
    • Make the cubic piece moveable by wiggling under it with an opening pick or spudger.
  7. LG V50 ThinQ Speaker & Charging Port Replacement: 7 단계, 이미지 1개 중 1개
    • Remove bottom circuiting, the speaker system is a part of the bottom circuit board.
결론
작성자
3다른 기여자 명과 함께
William Martin
회원 가입일: 11/01/23
231 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 348
