주요 콘텐츠로 건너뛰기
Lenovo ThinkPad P50s Keyboard Replacement
Don Pangottil
Don Pangottil3 다른 기여자
최종 수정일 December 20, 2024
10 - 20 분
조정
Is your Lenovo ThinkPad P50s keyboard not performing as expected? If you're dealing with a worn-out key or a complete keyboard malfunction, try out these solutions on the keyboard troubleshooting page. If those don't seem to work, follow this guide which walks you through the process step-by-step on how to replace your keyboard. With a minimal amount of tools, easy-to-follow instructions, and helpful tips, you'll be able to replace your keyboard with ease.
Before you begin this guide, you should disable the built-in battery. Here is a link with instructions on how to do so on page 123. You should also disconnect the AC power adapter and turn off the laptop.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad P50s Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
  4. Lenovo ThinkPad P50s Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Use a spudger to push on the indents in the keyboard approximately 2.5 mm forward to reveal the 1.7 mm screws.
    • While the images show a metal spudger, you should avoid using one as it could damage the electronics of the device.
  5. Lenovo ThinkPad P50s Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws on the keyboard
    • Flip the keyboard forward to lie flat on the keys, exposing the two ribbons.
    • Be careful not to rip the ribbons when you flip the keyboard over.
  6. Lenovo ThinkPad P50s Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use a spudger or a clean fingernail to flip up the locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cables out of their sockets.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • Remove the keyboard from the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
3다른 기여자 명과 함께
Don Pangottil
회원 가입일: 09/09/24
197 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 12
전체 시간: 56
