주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys WAP54g LED Lights Replacement
필요한 것
  1. Linksys WAP54g LED Lights Replacement, Top Casing: 1 단계, 이미지 1개 중 1개
    • Power down and unplug the device.
    댓글 쓰기
  2. Linksys WAP54g LED Lights Replacement: 2 단계, 이미지 1개 중 1개
    댓글 쓰기
  3. Linksys WAP54g LED Lights Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
    댓글 쓰기
  4. Linksys WAP54g LED Lights Replacement: 4 단계, 이미지 1개 중 1개
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
    댓글 쓰기
  5. Linksys WAP54g LED Lights Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
    댓글 쓰기
  6. Linksys WAP54g LED Lights Replacement: 6 단계, 이미지 1개 중 1개
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
    댓글 쓰기
  7. Linksys WAP54g LED Lights Replacement: 7 단계, 이미지 2개 중 1개 Linksys WAP54g LED Lights Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
    댓글 쓰기
  8. Linksys WAP54g LED Lights Replacement: 8 단계, 이미지 2개 중 1개 Linksys WAP54g LED Lights Replacement: 8 단계, 이미지 2개 중 2개
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
    댓글 쓰기
  9. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: 9 단계, 이미지 2개 중 1개 Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: 9 단계, 이미지 2개 중 2개
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
    댓글 쓰기
  10. Linksys WAP54g LED Lights Replacement, LED Lights: 10 단계, 이미지 1개 중 1개
    • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
    • For help with soldering or desoldering refer to ifixit's soldering guide: 연결부 납땜 및 납제거 방법
    댓글 쓰기
  11. Linksys WAP54g LED Lights Replacement: 11 단계, 이미지 1개 중 1개
    • Place new LED lights through holes created by desoldering and removing old lights.
    댓글 쓰기
  12. Linksys WAP54g LED Lights Replacement: 12 단계, 이미지 2개 중 1개 Linksys WAP54g LED Lights Replacement: 12 단계, 이미지 2개 중 2개
    • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
    • Follow the Installing the Casing guide in reverse to re-assemble your device.
    댓글 쓰기
결론
Once the soldering is complete, the device should work and the LED lights should light up.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Derek Myers
회원 가입일: 10/04/11
288 평판
안내서 5개를 작성함
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 2,428
