주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys WRT54GS v2 Power Connector Replacement
필요한 것
    1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: 1 단계, 이미지 1개 중 1개
      • Turn the router over so that all four of its feet are facing upwards.
      댓글 쓰기
    2. Linksys WRT54GS v2 Power Connector Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the rubber inserts inside the the two purple feet located on the router's front case.
      • This may be a challenge, so try the following two methods:
      • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
      • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
      댓글 쓰기
    3. Linksys WRT54GS v2 Power Connector Replacement: 3 단계, 이미지 1개 중 1개
      • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
      댓글 쓰기
    4. Linksys WRT54GS v2 Power Connector Replacement: 4 단계, 이미지 1개 중 1개
      • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
      댓글 쓰기
    1. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Slide the board unit out and up.
      댓글 쓰기
    2. Linksys WRT54GS v2 Power Connector Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
      • Slide the back cover out and away from the circuit board.
      댓글 쓰기
    1. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: 7 단계, 이미지 1개 중 1개
      • Turn the circuit board over.
      • Identify the solder connections on the board, marked in red.
      댓글 쓰기
    2. Linksys WRT54GS v2 Power Connector Replacement: 8 단계, 이미지 1개 중 1개
      • Desolder the connection by following iFixit's guide to repairing soldered connections: 연결부 납땜 및 납제거 방법.
      • Remove the Power Connector from the board.
      • Insert the replacement power port and resolder the connectors.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Alex Do
회원 가입일: 10/12/11
51 평판
안내서 1개를 작성함
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 회원
CPSU-REGAN-F11S3G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 2,234
