주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Air 2022 (M2) Screen Replacement
필요한 것
    1. MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 1 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 1 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 1 단계, 이미지 3개 중 3개
      • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
      • Power off your MacBook Air and unplug all cables.
      • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
      댓글 쓰기
    2. MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: 2 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      FixMat
      $36.95
      • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
      • Two screws with a short threaded portion near the hinges
      • Two screws with a long threaded portion near the front of the MacBook
      댓글 쓰기
    3. MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
      • Apply a suction handle to the center of the lower case's front edge.
      • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
      • Insert an opening pick into the gap.
      댓글 쓰기
    4. MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 4 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 4 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 4 단계, 이미지 3개 중 3개
      • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
      • Slide the pick to the bottom right corner to release the first clip.
      • Slide the pick around the corner and up the right edge to release the next clip.
      댓글 쓰기
    5. MacBook Air 2022 (M2) Screen Replacement: 5 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 5 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Insert the opening pick in the original gap created with the suction handle.
      • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
      댓글 쓰기
    6. MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 6 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 6 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 6 단계, 이미지 3개 중 3개
      • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
      • Don't pull up until the cover is completely separated.
      댓글 쓰기
    7. MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 7 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 7 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 7 단계, 이미지 3개 중 3개
      • Remove the lower case.
      • During reassembly:
      • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
      • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
      • You'll hear and feel a distinct click as each clip snaps into place.
      댓글 쓰기
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the battery connector cover: 8 단계, 이미지 1개 중 1개
      • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
      댓글 쓰기
    2. MacBook Air 2022 (M2) Screen Replacement: 9 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the battery connector cover.
      댓글 쓰기
    3. MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 2개
      • Use an opening pick to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      댓글 쓰기
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: 11 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: 11 단계, 이미지 2개 중 2개
      • Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
      댓글 쓰기
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: 12 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: 12 단계, 이미지 2개 중 2개
      • Use a T3 Torx driver to remove the nine 1.5 mm screws securing the four metal covers.
      댓글 쓰기
    2. MacBook Air 2022 (M2) Screen Replacement: 13 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 13 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 13 단계, 이미지 3개 중 3개
      • Remove the four metal covers:
      • Two speaker cable covers
      • One display cable cover
      • One antenna cable cover
      댓글 쓰기
    3. MacBook Air 2022 (M2) Screen Replacement: 14 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the four screws securing the upper display cable cover:
      • Two 2.5 mm P2 Pentalobe screws
      • Two 2.5 mm 3IP Torx plus screws
      • During reassembly, the Pentalobe screws must thread into the display cable securing bracket.
      댓글 쓰기
    4. MacBook Air 2022 (M2) Screen Replacement: 15 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 15 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 15 단계, 이미지 3개 중 3개
      • Remove the upper display cable cover and plastic securing bracket.
      • During reassembly, make sure the top edge of the upper display cable cover is under the securing bracket.
      댓글 쓰기
    5. MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 16 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 16 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 16 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
      댓글 쓰기
    6. MacBook Air 2022 (M2) Screen Replacement: 17 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 17 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 17 단계, 이미지 3개 중 3개
      • Disconnect the left and right speaker press connectors.
      댓글 쓰기
    7. MacBook Air 2022 (M2) Screen Replacement: 18 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 18 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 18 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
      • Lift straight up to disconnect the cable.
      • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
      • Repeat for the second antenna cable.
      • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
      댓글 쓰기
    8. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: 19 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: 19 단계, 이미지 2개 중 2개
      • These screws strip easily. Apply constant, downward force to prevent stripping.
      • Use a 3IP Torx Plus driver to remove the two 2.6 mm screws securing the right and left hinge covers.
      댓글 쓰기
    9. MacBook Air 2022 (M2) Screen Replacement: 20 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 20 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 20 단계, 이미지 3개 중 3개
      • Grip the left hinge cover with blunt nose tweezers.
      • Pull the cover towards the bottom of the laptop and upwards to free it from its recess.
      • Pull up and remove the hinge cover.
      댓글 쓰기
    10. MacBook Air 2022 (M2) Screen Replacement: 21 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 21 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 21 단계, 이미지 3개 중 3개
      • Repeat the previous step to remove the right hinge cover.
      댓글 쓰기
    11. MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: 22 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: 22 단계, 이미지 2개 중 2개
      • Remove the six screws securing the left and right speakers:
      • Four 5.6 mm 4IP Torx Plus screws (two on each speaker)
      • Two 3.5 mm T5 Torx screws (one on each speaker)
      댓글 쓰기
    12. MacBook Air 2022 (M2) Screen Replacement: 23 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 23 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement: 23 단계, 이미지 3개 중 3개
      • Lift the speakers straight up and remove them.
      댓글 쓰기
    13. MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: 24 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: 24 단계, 이미지 2개 중 2개
      • Use a T3 Torx screwdriver to remove the two 1.5 mm screws securing the lid-angle sensor connector cover.
      댓글 쓰기
    14. MacBook Air 2022 (M2) Screen Replacement: 25 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 25 단계, 이미지 2개 중 2개
      • Remove the lid-angle sensor connector cover.
      댓글 쓰기
    15. MacBook Air 2022 (M2) Screen Replacement: 26 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 26 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to pry up and disconnect lid angle sensor press connector.
      댓글 쓰기
    16. MacBook Air 2022 (M2) Screen Replacement: 27 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement: 27 단계, 이미지 2개 중 2개
      • Gently peel the lid angle sensor cable from the top of the headphone jack and move it out of the way.
      댓글 쓰기
    17. MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 28 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 28 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 28 단계, 이미지 3개 중 3개
      • Check if your replacement screen has a lid‑angle sensor installed on the hinge. If it does, skip this step. Otherwise, follow this step to remove the sensor—you'll need to transfer it to your replacement screen.
      • Use the point of a spudger to lift the flap covering the lid‑angle sensor screw, located on the left hinge.
      • Use a 1IP Torx Plus driver to remove the screw securing the lid‑angle sensor.
      • Remove the lid‑angle sensor and set it aside for reassembly.
      댓글 쓰기
    18. MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: 29 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: 29 단계, 이미지 2개 중 2개
      • Use an 8IP Torx Plus driver to loosen (not remove) the six hinge screws.
      댓글 쓰기
    19. MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: 30 단계, 이미지 2개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: 30 단계, 이미지 2개 중 2개
      • Fully open your MacBook and gently place it keyboard side down on a table so the screen hangs over the edge.
      댓글 쓰기
    20. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 31 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 31 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 31 단계, 이미지 3개 중 3개
      • Support the screen with one hand and use your free hand to remove the six 4.3 mm 8IP Torx Plus screws securing the hinges.
      • Keep a firm grip on your laptop, as it can easily fall off the table.
      댓글 쓰기
    21. MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 32 단계, 이미지 3개 중 1개 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 32 단계, 이미지 3개 중 2개 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 32 단계, 이미지 3개 중 3개
      • Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
      • Make sure the screen hinges are fully open and guide them into their recesses in the frame.
      • Install and partially tighten the six hinge screws.
      • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
      • Fully tighten the hinge screws.
      댓글 쓰기
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 42명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
199,122 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 61,687개를 작성함
43가이드 댓글
Does the screen display normally after replacing it with the aftermarket screen? As far as I know, after 2021, MacBooks have problems with screen output when they are replaced with aftermarket screens.
https://www.ifixit.com/News/73288/m2-mac...
wellbinnn - 답글 공유
Hi! We tested swapping screens between two M2 MacBook Airs and didn't find any issues with the screen. The problem is with the MacBook Pros.
Spencer Day - 답글 공유
I checked your comment. Thanks for checking!
wellbinnn - 답글 공유
Is this doable without scratching or chipping the body if done using the ifixit tool kit?
John Mashconzone - 답글 공유
Hello! It's definitely doable! If you're worried, I would take extra care when standing the laptop up to make sure you set it on a surface that won't scratch the body. Also, be careful when guiding the hinges out of the frame to avoid brushing against the frame.
Spencer Day - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 111
지난 7일: 807
지난 30일: 3,824
전체 시간: 138,092
