주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 13" 2022 (M2) Battery Replacement
필요한 것
    1. MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 3개
      • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug all cables and fully shut down your MacBook.
      • Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
      • Opening the lid will power on your MacBook. If you're using macOS Big Sur v11.1 or earlier, disable this function using this guide.
      댓글 쓰기
    1. MacBook Pro 13" 2022 (M2) Battery Replacement, Unfasten the lower case: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      FixMat
      $36.95
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.8 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      댓글 쓰기
    2. MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the lower case: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the lower case: 3 단계, 이미지 2개 중 2개
      • Apply a suction handle near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle to create a gap between the lower case and the frame.
      댓글 쓰기
    3. MacBook Pro 13" 2022 (M2) Battery Replacement, Release the left clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the left clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the left clips: 4 단계, 이미지 3개 중 3개
      • Insert an opening pick between the lower case and the frame.
      • Slide the pick around the left corner to release the first set of clips.
      • You'll hear and feel a pop when each clip releases.
      댓글 쓰기
    4. MacBook Pro 13" 2022 (M2) Battery Replacement, Release the right clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the right clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the right clips: 5 단계, 이미지 3개 중 3개
      • Slide your opening pick around the right corner to release the second set of clips securing the lower case.
      댓글 쓰기
    5. MacBook Pro 13" 2022 (M2) Battery Replacement, Pry the lower case up: 6 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Pry the lower case up: 6 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Pry the lower case up: 6 단계, 이미지 3개 중 3개
      • Insert your opening pick between the lower case and the frame near the middle left screw hole.
      • Firmly twist the pick until the clip releases.
      • Repeat this procedure for the clip near the middle right screw hole.
      댓글 쓰기
    6. MacBook Pro 13" 2022 (M2) Battery Replacement, Release the remaining clips: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the remaining clips: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Release the remaining clips: 7 단계, 이미지 3개 중 3개
      • Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
      • This motion requires significant force. Don't pull the lower case up, as you may bend the clips.
      • If it feels stuck, pull one corner at a time.
      댓글 쓰기
    7. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the lower case: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the lower case: 8 단계, 이미지 2개 중 2개
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
      • Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
      • You'll hear and feel a pop when each clip engages.
      댓글 쓰기
    1. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery board cover: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery board cover: 9 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
      댓글 쓰기
    2. MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the battery data cable: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the battery data cable: 10 단계, 이미지 2개 중 2개
      • Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
      • Don't remove or tear the pull tab, as it's attached to the head of the connector.
      댓글 쓰기
    3. MacBook Pro 13" 2022 (M2) Battery Replacement: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Use the point of a spudger to flip up the small locking tab securing the battery data connector.
      • Locking tabs on ZIF connectors are fragile—be gentle with your spudger.
      댓글 쓰기
    4. MacBook Pro 13" 2022 (M2) Battery Replacement: 12 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement: 12 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement: 12 단계, 이미지 3개 중 3개
      • Use blunt nose tweezers or your fingers to grab the battery data cable pull tab and slide it straight out of its socket.
      • Move the cable to the left, out of the way of the battery board.
      • Don't strain the cable, as it's still attached to the battery board.
      댓글 쓰기
    5. MacBook Pro 13" 2022 (M2) Battery Replacement, Unfasten the battery connector: 13 단계, 이미지 1개 중 1개
      • Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
      댓글 쓰기
    6. MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 3개
      • Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
      • Lifting the connector too high will break it. Angle it enough so it won't accidentally contact the battery board during repair.
      • Optionally, you may insert a barrier, such as a piece of a playing card, between the connector and the board during the repair.
      댓글 쓰기
    1. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the trackpad cable bracket: 15 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the trackpad cable bracket: 15 단계, 이미지 2개 중 2개
      • Use your T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable bracket.
      • Remove the bracket.
      댓글 쓰기
    2. MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the trackpad: 16 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Disconnect the trackpad: 16 단계, 이미지 2개 중 2개
      • Use the flat end of your spudger to pry up and disconnect the trackpad cable from the logic board.
      댓글 쓰기
    3. MacBook Pro 13" 2022 (M2) Battery Replacement, Heat the trackpad cable: 17 단계, 이미지 1개 중 1개
      댓글 쓰기
    4. MacBook Pro 13" 2022 (M2) Battery Replacement, Reposition the trackpad cable: 18 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Reposition the trackpad cable: 18 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Reposition the trackpad cable: 18 단계, 이미지 3개 중 3개
      • Use your fingers to peel the trackpad cable from the battery.
      • Fold the cable over the front edge of the MacBook.
      • Don't strain the cable, as it's still connected to the trackpad.
      댓글 쓰기
    5. MacBook Pro 13" 2022 (M2) Battery Replacement, Unfasten the trackpad: 19 단계, 이미지 1개 중 1개
      • Use your T5 Torx driver to remove the ten screws securing the trackpad:
      • Two 4.3 mm screws
      • Eight 5.8 mm screws
      댓글 쓰기
    6. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 3개
      • Open your MacBook by lifting the body away from the display and trackpad.
      • Feed the trackpad cable through its cutout in the frame.
      • Before reinstalling the trackpad, thread the trackpad cable through the narrower of two slots at the base of the frame.
      댓글 쓰기
    7. MacBook Pro 13" 2022 (M2) Battery Replacement: 21 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement: 21 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement: 21 단계, 이미지 3개 중 3개
      • Remove the trackpad from the display.
      • Be careful not to lose the six small washers from the trackpad screw posts:
      • Four rectangular washers
      • Two circular washers
      댓글 쓰기
    1. MacBook Pro 13" 2022 (M2) Battery Replacement, Uncover the left battery board screw: 22 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Uncover the left battery board screw: 22 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use blunt nose tweezers or your fingers to remove the rubber cover adhered to the left battery board screw.
      댓글 쓰기
    2. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery data cable: 23 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery data cable: 23 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery data cable: 23 단계, 이미지 3개 중 3개
      • Use blunt nose tweezers or your fingers to grab near the head of the cable and slide it straight out of its socket.
      • Remove the cable.
      댓글 쓰기
    3. MacBook Pro 13" 2022 (M2) Battery Replacement, Unfasten the battery board: 24 단계, 이미지 1개 중 1개
      • Use your T5 Torx driver to remove the two 3.1 mm screws securing the battery board.
      댓글 쓰기
    4. MacBook Pro 13" 2022 (M2) Battery Replacement, Reposition the battery board: 25 단계, 이미지 1개 중 1개
      • Insert the flat end of your spudger between the top edge of the battery board and the frame.
      • Lift the board from its recess.
      • Be careful not to catch on the battery connector.
      댓글 쓰기
    5. MacBook Pro 13" 2022 (M2) Battery Replacement, Protect the display: 26 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Protect the display: 26 단계, 이미지 2개 중 2개
      • Liquid adhesive remover may damage the antireflective coating on your MacBook's display.
      • Open your MacBook's lid and place a sheet of aluminum foil between the display and keyboard. Leave it in place while you remove the battery.
      • Place an absorbent towel under the trackpad's recess to soak up any excess adhesive remover.
      • Close the lid and continue disassembly.
      댓글 쓰기
    6. MacBook Pro 13" 2022 (M2) Battery Replacement, Use skin and eye protection: 27 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Use skin and eye protection: 27 단계, 이미지 2개 중 2개
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling adhesive remover.
      • Do not wear contact lenses without eye protection.
      • Put on gloves to prevent skin irritation.
      댓글 쓰기
    7. MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare the adhesive remover: 28 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare the adhesive remover: 28 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Prepare the adhesive remover: 28 단계, 이미지 3개 중 3개
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed.
      댓글 쓰기
    8. MacBook Pro 13" 2022 (M2) Battery Replacement, Soften the adhesive: 29 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Soften the adhesive: 29 단계, 이미지 2개 중 2개
      • Apply a few drops of adhesive remover under the front edge of the left battery cell.
      댓글 쓰기
    9. MacBook Pro 13" 2022 (M2) Battery Replacement: 30 단계, 이미지 1개 중 1개
      • Tilt the front edge of your MacBook up to allow the adhesive remover to flow underneath the battery cell.
      • Wait two minutes for the adhesive to soften.
      댓글 쓰기
    10. MacBook Pro 13" 2022 (M2) Battery Replacement, Insert a plastic card: 31 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Insert a plastic card: 31 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Insert a plastic card: 31 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Slide a plastic card under the front edge of the left battery cell.
      • If you can't insert your card, gently twist it to help create a gap.
      댓글 쓰기
    11. MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the left battery cell: 32 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the left battery cell: 32 단계, 이미지 2개 중 2개
      • Slide your plastic card deeper under the battery cell to separate its adhesive.
      • Don't force the card under the battery. If it feels stuck, apply a few more drops of adhesive remover and try again.
      댓글 쓰기
    12. MacBook Pro 13" 2022 (M2) Battery Replacement: 33 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement: 33 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement: 33 단계, 이미지 3개 중 3개
      • Twist your plastic card to lift the battery cell from the frame.
      • Don't try to remove the cell yet, as it's still attached to the other cells.
      • Leave your card in place to prevent the cell from readhering while you separate the other cells.
      댓글 쓰기
    13. MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the right battery cell: 34 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the right battery cell: 34 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the right battery cell: 34 단계, 이미지 3개 중 3개
      • Separate the right battery cell with your adhesive remover and plastic card, just as you did for the left cell.
      댓글 쓰기
    14. MacBook Pro 13" 2022 (M2) Battery Replacement, Soften the adhesive: 35 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Soften the adhesive: 35 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Soften the adhesive: 35 단계, 이미지 3개 중 3개
      • Prop up the back edge of your MacBook with a book or similarly-sized object so your adhesive remover flows away from the logic board and under the middle battery cell.
      • Apply a few drops of adhesive remover to the inside edge of the middle battery cell.
      댓글 쓰기
    15. MacBook Pro 13" 2022 (M2) Battery Replacement: 36 단계, 이미지 2개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement: 36 단계, 이미지 2개 중 2개
      • Cutouts in the frame between the battery and trackpad may prevent the adhesive remover from flowing completely underneath the battery.
      • Apply a few drops of adhesive remover to the sides of the middle battery cell to soften the remaining adhesive.
      댓글 쓰기
    16. MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the middle battery cell: 37 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the middle battery cell: 37 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Separate the middle battery cell: 37 단계, 이미지 3개 중 3개
      • Slide one of your plastic cards under either side of the middle battery cell.
      • Avoid sliding your card near the battery board or logic board.
      • Use your card to separate the battery cell from the frame.
      댓글 쓰기
    17. MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery: 38 단계, 이미지 3개 중 1개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery: 38 단계, 이미지 3개 중 2개 MacBook Pro 13" 2022 (M2) Battery Replacement, Remove the battery: 38 단계, 이미지 3개 중 3개
      • Lift and remove the battery.
      • To install a new battery:
      • Use your fingers to pull off large pieces of adhesive.
      • Soak any remaining pieces with adhesive remover and scrape them away with your spudger. Clean any residual adhesive remover.
      • Before removing any adhesive liners, place the new battery into the frame to make sure it fits.
      • Remove all adhesive liners and firmly press each cell into place.
      댓글 쓰기
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
106,001 평판
안내서 472개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 40,680개를 작성함
2가이드 댓글
I see from other articles this used adhesive strips Is this not the case?
Can this be verified?
https://everymac.com/systems/apple/macbo...
and
MacBook Pro's battery is held in place by 14 adhesive strips and one screw, with pull tabs that may break and require isopropyl alcohol for safe removal. The M2 chip and logic board in this unit are difficult to access, but since nothing is repairable or upgradeable, it's unlikely anyone will need to be in there.
Ryan Zmuda - 답글 공유
Bonjour et merci pour ce tutoriel … mais je ne comprends pas trop le différentiel de temps et niveau de difficulté entre ce remplacement sur un MBP 2021 et un 2022, car les tutoriels ont les mêmes étapes mais l'un donne 1 ou 2h en modéré quand l'autre donne 2 ou 3h en difficile ... donc ??
Merci de vos précisions ;o)
Bruno DEMAS - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 31
지난 7일: 302
지난 30일: 1,354
전체 시간: 38,777
