주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Make a Fabric Patch
필요한 것
    1. Make a Fabric Patch, Choose the patch fabric: 1 단계, 이미지 3개 중 1개 Make a Fabric Patch, Choose the patch fabric: 1 단계, 이미지 3개 중 2개 Make a Fabric Patch, Choose the patch fabric: 1 단계, 이미지 3개 중 3개
      • To choose the ideal patch fabric for performance and aesthetics, take the following aspects into consideration and match them to the garment:
      • Weave Structure - Whether the fabric is woven or knit.
      • Fiber Content - The fiber that the fabric is made of (cotton, nylon, etc). This will likely be written somewhere on the garment tag.
      • Weight - How thick and rigid the fabric feels.
      • Stretch - Whether the fabric stretches horizontally, vertically, or both.
      • Color - Matching color is up to personal discretion but often a slightly darker fabric will look less obvious than a slightly lighter fabric.
      • Preference - A preference for a contrasting patch for a more visible repair.
      댓글 쓰기
    2. Make a Fabric Patch, Example: Choose the patch fabric: 2 단계, 이미지 1개 중 1개
      • In the pictured example, the damaged garment is non-stretch woven, heavyweight organic cotton in a medium tan color. Here's a breakdown of the pros and cons each of the fabric patch options:
      • All of the pictured fabric samples are woven.
      • Options 1 - 4 are heavyweight organic non-stretch cotton in a variety of colors.
      • Option 5 is very close in color, but is woven nylon with noticeable stretch.
      • Option 6 is close in color and cotton, but is medium weight.
      • Option 7 is a medium weight cotton in a contrast print.
      • The ideal match fabric is Option 1 because it's close in color and has the same fiber content, weave structure, stretch, and weight.
      • Options 3, 4 and 7 could be chosen for contrast patches. However, Option 7 may be too lightweight for long term durability.
      댓글 쓰기
    3. Make a Fabric Patch, Iron the patch fabric: 3 단계, 이미지 1개 중 1개
      • Choose your patch fabric and iron or steam the fabric so it's smooth and free of wrinkles.
      댓글 쓰기
    4. Make a Fabric Patch, Measure the damage: 4 단계, 이미지 2개 중 1개 Make a Fabric Patch, Measure the damage: 4 단계, 이미지 2개 중 2개
      • Measure the dimensions of the damage.
      • Follow the grain lines of the garment fabric, measuring in each grain direction to get the width and height of the damage.
      • Remember these measurements for the next step.
      댓글 쓰기
    5. Make a Fabric Patch, Determine the patch dimensions: 5 단계, 이미지 3개 중 1개 Make a Fabric Patch, Determine the patch dimensions: 5 단계, 이미지 3개 중 2개 Make a Fabric Patch, Determine the patch dimensions: 5 단계, 이미지 3개 중 3개
      • Add at least 1/2 inch (~13 mm) in each direction—so at least 1 inch (~25 mm) total—to each damage dimension measurement from the previous step.
      • These new measurements will be the final patch size, which is the size of the patch when it's sewn on.
      • The fabric directly surrounding the damage is weak and unable to hold stitching. This additional space ensures the patch can be securely attached and provides a buffer in case the damage grows.
      • Optionally, mark the size and orientation of the patch onto the garment.
      댓글 쓰기
    6. Make a Fabric Patch, Mark the patch measurements: 6 단계, 이미지 3개 중 1개 Make a Fabric Patch, Mark the patch measurements: 6 단계, 이미지 3개 중 2개 Make a Fabric Patch, Mark the patch measurements: 6 단계, 이미지 3개 중 3개
      • Use chalk or heat-erasable pen to mark the final patch dimensions found in the previous step onto the right (front) side of the patch fabric.
      • Be sure that the edges of the patch follow the grain directions of the patch fabric. The grain direction of the patch should match the grain direction of the garment for the best appearance and performance.
      • In the pictured repair, the patch fabric has a diagonal print pattern in relation to the fabric grain.
      댓글 쓰기
    7. Make a Fabric Patch, Add seam allowance: 7 단계, 이미지 2개 중 1개 Make a Fabric Patch, Add seam allowance: 7 단계, 이미지 2개 중 2개
      • Add 1/2 inch (~13 mm) to each side of the drawn patch dimensions and mark these new lines using chalk or heat-erasable pen.
      • This is for seam allowance, additional fabric that will be folded under so that the raw fabric edges of the patch don't show when the repair is complete.
      댓글 쓰기
    8. Make a Fabric Patch, Cut the patch: 8 단계, 이미지 2개 중 1개 Make a Fabric Patch, Cut the patch: 8 단계, 이미지 2개 중 2개
      • Cut out the patch along the seam allowance lines.
      • Use sharp scissors, ideally ones that aren't used to cut paper or tape.
      댓글 쓰기
    9. Make a Fabric Patch, Fold the seam allowance: 9 단계, 이미지 2개 중 1개 Make a Fabric Patch, Fold the seam allowance: 9 단계, 이미지 2개 중 2개
      • Using the guidelines on the patch, iron the seam allowance inward toward the backside of the patch.
      • Repeat on each side.
      댓글 쓰기
    10. Make a Fabric Patch, Miter the patch corners: 10 단계, 이미지 2개 중 1개 Make a Fabric Patch, Miter the patch corners: 10 단계, 이미지 2개 중 2개
      • Miter each corner so no raw fabric is exposed at the edges of the patch. (See the next step for video instructions.)
      • Unfold the seam allowance on either side of the corner.
      • Use the fold lines to determine the diagonal line that bisects the point where the folds intersect.
      • Fold the corner inward along this diagonal line.
      • Refold the seam allowances of the adjacent patch sides. If done correctly, their corner edges will meet at a 45-degree angle.
      • Press the fabric in place and repeat on each corner.
      댓글 쓰기
      • This video shows how to miter a patch corner by following the instructions in the previous step.
      댓글 쓰기
    11. Make a Fabric Patch, Pin the patch in place: 12 단계, 이미지 1개 중 1개
      • Pin the patch in place over the damaged area using the guidelines created in Step 5 (the final patch dimensions).
      • Place the pins perpendicular to the patch edges, with the pin heads facing outward, for easy removal while sewing on the patch.
      댓글 쓰기
    12. Make a Fabric Patch, Troubleshooting: 13 단계, 이미지 3개 중 1개 Make a Fabric Patch, Troubleshooting: 13 단계, 이미지 3개 중 2개 Make a Fabric Patch, Troubleshooting: 13 단계, 이미지 3개 중 3개
      • CLOSE TEAR: In most cases, stitch the tear closed before attaching the patch. This will seal the tear on the inside so it doesn't grow bigger or get caught while the garment is being worn. See Whip Stitch on a Tear.
      • UNDERPATCH: If the tear is too large to be stitched closed, use an underpatch: a smaller patch that's sewn over the hole on the inside before the main patch is sewn on the front.
      • PATCH INTO A SEAM: For a patch that goes into a garment seam, use the same measurement steps but leave the seam allowance along that edge unfolded. The seam allowance will instead be sewn into the garment seam.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,568 평판
안내서 19개를 작성함
Patagonia Patagonia 회원
Community
9 회원들
안내서 245개를 작성함
2가이드 댓글
Doesn't the seam in the garment need to be opened in order to sew the patch into the seam? If so, what should be done to keep the threading in the cut open seam from loosening and freying during use and laundering?
Toni - 답글 공유
Hey Toni! Yes, if you want to sew a patch into an existing seam, you'll need to carefully unpick the stitches and open the seam first.
When you re-sew the seam after the patch is attached:
(1) Overlap the existing stitches by at least 1/2 inch on both ends, rather than starting and stopping exactly where the old stitching ended.
(2) Back-tack at both ends of the new stitch line. Back‑tacking simply means sewing forward and backward over the same spot two or three times (for about ½ inch).
These steps help secure the new seam and “lock down” the ends of the original stitching, which prevents loosening or fraying during regular wear and laundering.
Clara Redwood - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 57
지난 30일: 190
전체 시간: 2,128
