주요 콘텐츠로 건너뛰기
Microsoft Surface Book Battery Replacement
필요한 것
  1. Microsoft Surface Book Battery Replacement, Remove the display with the Detach button: 1 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Remove the display with the Detach button: 1 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Remove the display with the Detach button: 1 단계, 이미지 3/3
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. Microsoft Surface Book Battery Replacement, Manually detach the display: 2 단계, 이미지 1/2 Microsoft Surface Book Battery Replacement, Manually detach the display: 2 단계, 이미지 2/2
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. Microsoft Surface Book Battery Replacement, Bend a paper clip: 3 단계, 이미지 1/2 Microsoft Surface Book Battery Replacement, Bend a paper clip: 3 단계, 이미지 2/2
    • Straighten out one section of a paper clip.
  4. Microsoft Surface Book Battery Replacement, Push the paper clip into the hole: 4 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Push the paper clip into the hole: 4 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Push the paper clip into the hole: 4 단계, 이미지 3/3
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. Microsoft Surface Book Battery Replacement, Release the mechanism: 5 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Release the mechanism: 5 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Release the mechanism: 5 단계, 이미지 3/3
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. Microsoft Surface Book Battery Replacement, Detach the second side: 6 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Detach the second side: 6 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Detach the second side: 6 단계, 이미지 3/3
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. Microsoft Surface Book Battery Replacement, Remove the display: 7 단계, 이미지 1/1
    • Completely power down your Surface Book before opening it up for any repairs.
  8. Microsoft Surface Book Battery Replacement, Screen: 8 단계, 이미지 1/1
    • Heat and apply an iOpener or use a hair dryer or heat gun to heat the perimeter of the screen, in order to soften the glue securing it.
  9. Microsoft Surface Book Battery Replacement, Anti-Clamp instructions: 9 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Anti-Clamp instructions: 9 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Anti-Clamp instructions: 9 단계, 이미지 3/3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your Surface Book so it rests level between the suction cups.
    • Position the suction cups near the middle of the bottom edge—one on the front, and one on the back.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  10. Microsoft Surface Book Battery Replacement: 10 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 10 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 10 단계, 이미지 3/3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  11. Microsoft Surface Book Battery Replacement: 11 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 11 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 11 단계, 이미지 3/3
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the bottom edge.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  12. Microsoft Surface Book Battery Replacement, Insert an opening pick: 12 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement, Insert an opening pick: 12 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement, Insert an opening pick: 12 단계, 이미지 3/3
    • The adhesive securing the screen is very strong. This step may take significant force and multiple attempts.
    • Apply a suction handle to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  13. Microsoft Surface Book Battery Replacement: 13 단계, 이미지 1/2 Microsoft Surface Book Battery Replacement: 13 단계, 이미지 2/2
    • Use the pick to slice all the way around the perimeter of the screen to separate the glue.
    • Do not insert the opening pick too far into the screen or you may cause damage to internal components.
    • Gently raise the screen but don't fully detach it until the cables underneath are disconnected.
  14. Microsoft Surface Book Battery Replacement: 14 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 14 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 14 단계, 이미지 3/3
    • Begin by removing the ribbon on the right. With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
  15. Microsoft Surface Book Battery Replacement: 15 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 15 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 15 단계, 이미지 3/3
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
    • Remove the screen.
  16. Microsoft Surface Book Battery Replacement, Battery: 16 단계, 이미지 1/2 Microsoft Surface Book Battery Replacement, Battery: 16 단계, 이미지 2/2
    • Use a T3 Torx driver to remove the 24 screws.
    • You don't need to remove the screw along the plastic piece that contains the camera lenses. Remove the two screws at either end of the keyboard connector.
  17. Microsoft Surface Book Battery Replacement: 17 단계, 이미지 1/2 Microsoft Surface Book Battery Replacement: 17 단계, 이미지 2/2
    • Next, using a metal spudger, disconnect the ribbon from the charging port.
    • Ensure that you gently remove the ribbon.
  18. Microsoft Surface Book Battery Replacement: 18 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 18 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 18 단계, 이미지 3/3
    • Remove the black plastic strip.
    • Then use a metal spudger to remove the ribbon under the black strip.
    • Make sure that you gently remove the ribbon.
  19. Microsoft Surface Book Battery Replacement: 19 단계, 이미지 1/3 Microsoft Surface Book Battery Replacement: 19 단계, 이미지 2/3 Microsoft Surface Book Battery Replacement: 19 단계, 이미지 3/3
    • Gently raise the motherboard slightly.
    • Don't manhandle the motherboard.
    • Use a plastic spudger to gently pry the battery. The battery runs underneath the motherboard. Pull free to the right.
결론
다른 64명이 해당 안내서를 완성하였습니다.
Wesley Kendrick
회원 가입일: 02/15/17
2,047 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-6, Sullivan Spring 2017 USF Tampa, Team 1-6, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G6
3 회원들
안내서 14개 작성하였습니다
댓글 79개
Good day, Where would you purchase the batteries. Both are swollen and need changing.
Shavaun - 답글
I got mine off ebay, just do a search, it was like 20 bucks.
sjsmith801 -
First thing’s first, MS will send you a new SurfaceBook Pro if your battery is swollen. They just replaced my 3yo SBP; I did not have an extended warranty and was definitely out of warranty support. Contact them before you attempt the repair on your own.
https://support.microsoft.com/en-ie/help...
Raymond Piller - 답글
They only replace machine under 3yo. They want 600USD after that
Colin Liew -
Hello I am overseas how do I contact MS
Francis Bassey -
댓글 쓰기
조회 통계:
24 시간 전: 137
7일 전: 865
30일 전: 4,098
전체 시간: 177,429
