Microsoft Zune 30 GB Logic Board Replacement
Remove the button pad ribbon cable and unscrew the logic board from the front screen of the Zune.
Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
Use the small flat head screw driver to gently lift the brown clamp.
The clamp will release the battery ribbon cable from the logic board, freeing the battery.
Now the back cover is off and the battery is removed, so the hard drive is clearly visible.
There are four 4.2 mm screws securing the hard drive to the logic board.
Remove all four screws using a Phillips #00 screwdriver.
Carefully detach the ribbon cable from the hard drive.
Now you have completely detached the hard drive.
The ribbon cable for the button sensor pad is attached with a small clamp to the bottom left corner of the logic board.
Use a small flathead screwdriver to lift the brown clasp and remove the ribbon cable.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Does anyone know where to get a replacement aftermarket faceplate for the zune 30 gb?
The piece extends inward to kind of sheath the connector itself so it takes a little back and forth between the sides.
jonathan - 답글
Also important to note that this piece only goes in one way, so take note of its orientation, and don't force it if it isn't sliding back in.
kazoodac - 답글
