Mini Muscle Massage Gun,Deep Tissue Percussion Massage Gun with 6 Speeds and 4 Heads, Type-C Charging,Ultra Quiet, Portable Electric Handheld Body Massager for Neck Back Pain Relief Tear down. 6 Variable Speed & 4 Massage Heads - The mini massage gun has 6-speed strength levels ranging from 1200 to 3200 rpm, which awakes your whole body muscles, from daily massage to deep massage. 4 interchangeable replacement heads fit your diverse needs and bring you a precision massage experience.
- Powerful & Super Quiet - Our massage gun deep tissue has a 30W high-torque motor and quite glide noise reduction technology that brings high power but low noise (35dB - 45dB) experience. You can use it at home, gym and office without causing a disturbance.
- Portable & 15 Minutes Auto-Off Protection - This percussion massage gun weighs only 580g, the hand feels light, comfortable to hold. It is designed with a 15 minute auto-off setting to prevent overheating to extend the life of the motor.
- High Battery Capacity & Type-c Charging - The muscle massage gun is equipped with a 1800mAh high-quality rechargeable lithium battery, that ensures 2-6 hours working time, and only takes 3-4 hours to fully charged. Equipped with a Type-C port that allows it to be charged as quickly and easily as a smartphone.
- Relax & Recover - The hand held massager features to relieve you from muscle tightness, soreness and back stiffness, a best way to rejuvenate muscle tissue and recover from body painfulness. The mini massager will help you in relieving fatigue after sports, workout, hiking, and climbing, which also suits for sedentary and postoperative recovery.
필요한 것
Dimension.
Red :98.30mm
Orange:116mm
Yellow:132.82mm
Diameter dimension
Red: 48.62mm Diameter
Hello 98.8mm Diameter
Unscrew all the screw hi lighted in the images.
unscrew the cap located at the tip of the device.
Battery length.
Orange. 66.64mm
Yellow: 71.28mm.
Battery Diameter.
Blue 42mm
Massage conector
Red:103.13mm
Device handle shell is weighted at 50g . Made from ABS plastic. Injection mold
Top shell is weighted at 19g. Made from ABS plastic
The tip which is used to hold the shell parts together is weighted at 19g. Made from ABS plastic
Back cap. This include the PCB. is weighted at 14g. Made from ABS plastic.
Bottom cap is weighted at 7g. Made from ABS plastic
Decoration parts. Non functional weighted at 3g.
Battery. Weighted at 72g. use to power the devic. 1800mAh lithium battery
Part connected to the device motor. Use as a connect to various massager head. Weighted at 19g.
Device motor. Weighted at 246g.
Red: Nylon: injection moulded
Blue: Rubber: injection moulded
Yellow: Eva foam:
Device design is quite simple which encourage repairability.
most part found in the device and be easily replace by purchasing them online
1800mAh high-quality rechargeable lithium battery can be easily replaced online.
30W high-torque motor can also be replace. Purchased online. https://www.hisgifts.com.au/products/sta...
Any broken parts of the shell can easily be fixed with 3d printing.
most screw can also be found online
