주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid 4 Battery Replacement
필요한 것
  1. Motorola Droid 4 Battery Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 1개 Motorola Droid 4 Battery Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 2개 Motorola Droid 4 Battery Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 3개
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
    댓글 쓰기
  2. Motorola Droid 4 Battery Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
    댓글 쓰기
  3. Motorola Droid 4 Battery Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid 4 Battery Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Gaetan
회원 가입일: 12/26/12
9,613 평판
안내서 18개를 작성함
17가이드 댓글
Jerk at the verizon store said this wasnt possible and tried to sell me a new phone, dumbass. Thanks for the guide!!
Rose M - 답글 공유
Worked great ! Ordered battery fro Amazon and with Torx kit...5 minute job !
Peter Kendrick - 답글 공유
Peter- I ordered a replacement and was able to change the battery. However, once in place, the phone would not boot up and would only show the battery icon with a question mark in it. Did you run in to this problem?
Ed Barton - 답글 공유
The battery in my phone started swelling so I ordered a battery from Amazon. Changing the battery was easy, but now the battery icon has a red question mark in it. How do I reset the battery icon?
Tracy - 답글 공유
Tracy -
I had the same problem.... Will be buying a new battery, torx screwdriver, and spludger tool and replacing the battery soon. Then I can use the phone as a backup device, or a second phone (new service needed for new line), in case my new Moto X dies....
Chris
Chris - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 77
전체 시간: 40,769
