주요 콘텐츠로 건너뛰기
Motorola Moto E4 Plus Battery Replacement
필요한 것
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: 2 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 2 단계, 이미지 2/2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Battery Replacement: 4 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 4 단계, 이미지 2/2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Battery Replacement: 5 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement: 5 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement: 5 단계, 이미지 3/3
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Battery Replacement: 6 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 6 단계, 이미지 2/2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Battery Replacement: 7 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 7 단계, 이미지 2/2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Battery Replacement: 8 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 8 단계, 이미지 2/2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: 9 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: 9 단계, 이미지 2/2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Battery Replacement, Battery: 10 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement, Battery: 10 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement, Battery: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to peel the ends of the two pull tabs off of the bottom edge of the battery.
  11. Motorola Moto E4 Plus Battery Replacement: 11 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement: 11 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement: 11 단계, 이미지 3/3
    • Pull out the left adhesive strip by steadily pulling the left tab at a flat angle.
    • If the adhesive strip rips, grab and twist the remaining stub around the tip of a pair of tweezers a couple of times and then continue pulling.
    • Repeat the same process for the right adhesive strip.
  12. Motorola Moto E4 Plus Battery Replacement: 12 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 12 단계, 이미지 2/2
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape.
    • In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery.
    • Press the new battery firmly into place for 5-10 seconds.
결론
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 19명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,959 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,420개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 112
전체 시간: 22,402
