주요 콘텐츠로 건너뛰기
Motorola Moto Z Play Battery Replacement
필요한 것
  1. Motorola Moto Z Play Battery Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
  2. Motorola Moto Z Play Battery Replacement: 2 단계, 이미지 1/1
    • Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto Z Play Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 3 단계, 이미지 3/3
    • In the following steps, you will separate the display assembly from the Moto Z Play's chassis.
    • For reference, refer to the first image, showing the back of the display assembly (right) after it has been removed from the phone (left).
    • If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the display panel and damage it.
    • Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the display panel, which is good news if you plan to reuse it.
  4. Motorola Moto Z Play Battery Replacement: 4 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 4 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 4 단계, 이미지 3/3
    • Apply a suction cup to the display, near the middle of the left edge.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  5. Motorola Moto Z Play Battery Replacement: 5 단계, 이미지 1/1
    • Insert an opening pick (or playing card) into the gap you opened behind the display.
  6. Motorola Moto Z Play Battery Replacement: 6 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 6 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 6 단계, 이미지 3/3
    • Slide the tool all along the left edge of the phone to slice through the adhesive securing the display.
  7. Motorola Moto Z Play Battery Replacement: 7 단계, 이미지 1/1
    • Heat the front of the phone between the display and the lower edge to soften the adhesive underneath.
  8. Motorola Moto Z Play Battery Replacement: 8 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 8 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 8 단계, 이미지 3/3
    • Slice through the glue under the lower bezel, being careful not to damage the fingerprint sensor.
    • Slide or roll your tool past the lower edge of the fingerprint sensor and continue to the other side. Do not pry directly underneath the sensor.
    • If you plan to re-use the display, be careful not to slice or pry at the display panel. Refer to this image to help identify the glued areas while avoiding the display panel (highlighted in red).
  9. Motorola Moto Z Play Battery Replacement: 9 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 9 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 9 단계, 이미지 3/3
    • Continue separating the glue underneath the rest of the lower bezel.
  10. Motorola Moto Z Play Battery Replacement: 10 단계, 이미지 1/1
    • Heat the right edge of the phone to soften the adhesive securing the right edge of the display.
  11. Motorola Moto Z Play Battery Replacement: 11 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 11 단계, 이미지 2/2
    • Slide your tool along the right edge of the phone to separate the glue securing the display.
  12. Motorola Moto Z Play Battery Replacement: 12 단계, 이미지 1/1
    • Heat the front of the phone between the display and the top edge.
  13. Motorola Moto Z Play Battery Replacement: 13 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 13 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 13 단계, 이미지 3/3
    • Insert your tool at the top right corner of the phone, and begin to slide it underneath the top bezel to separate the glue.
    • As before, if you want to re-use the display, don't insert the tool far enough to touch the display panel.
    • When your tool just passes the left edge of the earpiece speaker, stop.
    • Slide or roll your tool over the top of the flash module for the selfie camera to avoid damaging it.
  14. Motorola Moto Z Play Battery Replacement: 14 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 14 단계, 이미지 2/2
    • If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the display from the left edge and swing it open, away from the phone.
  15. Motorola Moto Z Play Battery Replacement: 15 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 15 단계, 이미지 2/2
    • While holding the display open, use the point of a spudger to pry up the locking tab on the fingerprint sensor cable's ZIF connector.
  16. Motorola Moto Z Play Battery Replacement: 16 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 16 단계, 이미지 2/2
    • At the opposite end of the phone, use your spudger to flip open the locking tab on the display cable connector.
    The locking tab on the is dark colored and runs almost the entire width of the ZIF connector. It is located on the opposite side from where the cable connects into. Pry upward from the bottom- it works like a hinge.
    Dewayne James - 답글
  17. Motorola Moto Z Play Battery Replacement: 17 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 17 단계, 이미지 2/2
    • Gently pull the fingerprint sensor cable to slide it out of its socket, disconnecting it from the motherboard.
  18. Motorola Moto Z Play Battery Replacement: 18 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 18 단계, 이미지 2/2
    • Gently pull the display cable to slide it out of its socket on the motherboard.
  19. Motorola Moto Z Play Battery Replacement: 19 단계, 이미지 1/1
    • Remove the display assembly.
  20. Motorola Moto Z Play Battery Replacement, Battery: 20 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the six 3.2 mm screws securing the lower cover.
    The repair kit that was bought for this phone came with the wrong size torx bit. Mine came with a T5 Torx which was bigger and I almost ruined the screw. I noticed it was not working and looked at the bit and in fact it was not the T3. Luckily I have the full kit and had a T3 Torx handy. Make sure to look at the Bits before using them. The screws are so fragile that they can get stripped easily.
    israel329 - 답글
    The kit comes with both a T3 and a T5—the T5 isn’t needed if all you’re doing is replacing the battery.
    Jeff Suovanen -
  21. Motorola Moto Z Play Battery Replacement: 21 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 21 단계, 이미지 2/2
    • Pry up and remove the lower cover.
    • If you use a tool, don't pry against the battery or motherboard.
  22. Motorola Moto Z Play Battery Replacement: 22 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 22 단계, 이미지 2/2
    • Use a spudger to disconnect the battery by prying its connector straight up from the motherboard.
  23. Motorola Moto Z Play Battery Replacement: 23 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 23 단계, 이미지 2/2
    • The battery is strongly glued into place.
    • Peel up the black pull tab at the top edge of the battery, and slowly pull it away from the battery at about a 45-degree angle to release the command strips (a.k.a. stretch-release adhesive) underneath.
    • If the command strips break or the black pull tab is missing, you can still remove the battery using heat and/or isopropyl alcohol to weaken the adhesive.
    • Apply some high concentration (>90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • Alternatively, apply a freshly heated iOpener to the back of the phone directly behind the battery for two minutes to help soften the adhesive. Re-heat and reapply the iOpener as necessary.
  24. Motorola Moto Z Play Battery Replacement: 24 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 24 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 24 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • When using tools to pry up the battery, be careful not to damage the two orange flex cables hidden underneath the battery's top edge.
    • Insert several opening picks or a plastic card along the outer edge of the battery.
    • Apply steady, even pressure to slowly lever the battery up and out of the phone.
    • If necessary, use several rounds of heating and pressure to slowly weaken the adhesive, and the battery will begin to separate.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    I did sever the orange flex cable as i was lifting the battery free. Is there anyway to repair this fragile cable?
    ty varszegi - 답글
  25. Motorola Moto Z Play Battery Replacement: 25 단계, 이미지 1/1
    • Continue pulling up the battery until all the adhesive releases from the rear case.
  26. Motorola Moto Z Play Battery Replacement: 26 단계, 이미지 1/1
    • Remove the battery.
    • Do not reuse the battery after it has been removed. The stress of removal can cause hidden damage to the battery cell, creating a potential safety hazard. Replace it with a new battery.
  27. Motorola Moto Z Play Battery Replacement: 27 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 27 단계, 이미지 2/2
    • Before installing your new battery, peel up all the old adhesive and remove it from the phone.
    • For best results, clean the area underneath the battery with isopropyl alcohol and a lint-free cloth or coffee filter. This helps prep the surface so the new battery will adhere more strongly.
  28. Motorola Moto Z Play Battery Replacement: 28 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 28 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 28 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
  29. Motorola Moto Z Play Battery Replacement: 29 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 29 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 29 단계, 이미지 3/3
    • Peel off the remaining film liners to expose the adhesive before pressing your new battery into place.
    • Carefully position the battery and press it firmly and evenly into the phone.
    • Connect the battery to the motherboard, and install the lower cover, including its six T3 Torx screws.
  30. Motorola Moto Z Play Battery Replacement, Display Installation: 30 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement, Display Installation: 30 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement, Display Installation: 30 단계, 이미지 3/3
    • Peel away and remove all the old display adhesive from the body of your phone.
    • If you're reinstalling your existing display, remove all the old adhesive from that as well.
    • Use the point of your spudger to scour away and remove any smaller bits of adhesive that remain stuck.
    • Be extremely careful not to accidentally puncture the battery with your spudger.
    • For best results, clean the area underneath the removed adhesive with isopropyl alcohol to help prep the surface so the new adhesive bonds more strongly.
  31. Motorola Moto Z Play Battery Replacement: 31 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 31 단계, 이미지 2/2
    • Some pre-cut adhesive sheets for the display contain up to three layers: a plastic liner (usually blue), an adhesive layer in the middle (black), and a wax paper liner (white).
    • If yours came with a paper liner, peel it away and remove it.
    where i buy this plastic
    ynwiam1990 - 답글
  32. Motorola Moto Z Play Battery Replacement: 32 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 32 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 32 단계, 이미지 3/3
    • Peel off and discard any remaining paper liner, exposing the adhesive on one side.
    • Before you continue, the adhesive sheet should look like the third image.
  33. Motorola Moto Z Play Battery Replacement: 33 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 33 단계, 이미지 2/2
    • Hold the adhesive sheet with the exposed adhesive facing down, and carefully align it into the lower edge of the phone.
    • Make sure the adhesive sheet is oriented correctly—the edge with multiple holes lines up with the bottom edge, and the rectangular cutout for the earpiece speaker lines up at the top.
    • When it's correctly aligned, lower the rest of the adhesive sheet into the phone.
  34. Motorola Moto Z Play Battery Replacement: 34 단계, 이미지 1/3 Motorola Moto Z Play Battery Replacement: 34 단계, 이미지 2/3 Motorola Moto Z Play Battery Replacement: 34 단계, 이미지 3/3
    • Firmly press the adhesive into place.
    • Use the flat edge of your spudger to press along the edges and hard-to-reach areas.
    • Be very careful not to accidentally puncture the battery with your spudger.
  35. Motorola Moto Z Play Battery Replacement: 35 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 35 단계, 이미지 2/2
    • Peel off and discard the plastic liner, exposing the display adhesive.
    Should the removal of the blue plastic backing wait until after verifying the screen works in the next step?
    amaismeierj - 답글
    Well, you can’t connect the screen with the plastic in the way. But in principle, you’re right—it wouldn’t be a bad idea to pause before installing the display adhesive, plug everything in, and verify that it works. Unfortunately, you then have to unplug it again to install the adhesive, so you’ll want to test it again once it’s plugged back in, but before sealing up your phone—just to make sure the cables are seated properly. So, the verification step is probably best left where it’s at.
    Jeff Suovanen -
    Well, I connected the screen to the motherboard without peeling off the plastic.
    It is possible!
    And after testing the phone I took off the plastic foil from the adhesive without unpluging the two connectors. The plasic foil herefor has two cuts in the area of the connectors .
    So I think it’s a good idea to swap step 35 to step 36.
    Thorsten Nüse - 답글
  36. Motorola Moto Z Play Battery Replacement: 36 단계, 이미지 1/2 Motorola Moto Z Play Battery Replacement: 36 단계, 이미지 2/2
    • Before sealing the display in place, connect the flex cables for the display and fingerprint sensor, and then power your phone on.
    • Test all functions to make sure your repair was successful before sealing up the display.
    • When fully inserted, the white line across each flex cable should be even with the markings on the motherboard on each side of the cable.
    • Do not remove, insert, or adjust the cables while the phone is powered on.
    • The cables can be tricky to align and install. Be sure not to touch the gold contacts on the back, or your finger oils may cause a malfunction. If you do accidentally touch them, wipe them gently with isopropyl alcohol.
    What if at this point my phone isnt turning on?
    bambibabygirl20 - 답글
  37. Motorola Moto Z Play Battery Replacement: 37 단계, 이미지 1/1
    • When your repair is tested and complete, press the display firmly into place and remove any plastic liners from the screen.
    • To help the display adhesive bond more securely, heat the perimeter of the display and then place the phone face-up under a heavy stack of books for 30 minutes.
    • Don't rest the phone on its camera bump while doing this, or the uneven pressure may prevent your display from adhering correctly. Place a couple thin books under the phone on either side of the camera bump to elevate it and keep the pressure in the right place.
결론
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
After completing this guide, calibrate your newly-installed battery.
다른 39명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
428,116 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 13개
Good instructions. 2 things to add. Be careful how much heat you apply, I damaged my screen. A real heat gun needed about 30 seconds. Second is you can get custom cut stickers for the Z play to reinstall the battery and screen they are from that big online company, you know the one.
Kris McLinden - 답글
One of the best guides ever: clear and precise, with a REAL step by step process. Thank you very much.
I only want to add something: on my model (EU) the battery is attached to the body by two striped along the short sides of the battery. It can be hard to work on those stripes so pur extra attention on that.
just.mro - 답글
Excellent guide. The biggest pain by far was removing the old battery. I didn’t have a heat gun so just used a hair dryer for the multiple rounds of heating and prying. I did end up deforming the old one quite a bit getting it out, but luckily nothing happened. Also, on my adhesive, the U-shaped cutout was *not* at the top left. Just make sure the speaker holes line up.
Simon Lai - 답글
Excellent instructions! I read it several times while waiting for my new battery to come from ifixit. I was pretty confident in my abilities and knew the risks of damaging the screen in the process. Sure enough, after going through the whole procedure and plugging my old screen back in, half of it was blank… Pretty sure I flexed the screen too much while lifting on it with the suction cup and cracked it. The screen is a lot thinner and flexible than I was expecting. I would have preferred to give more business to ifixit but I didn’t want to be down for another whole week so I had to order a new screen from online company with free 2 day shipping… No complaints towards the author or ifixit at all. I would attempt this repair again.
I just want to mention that even the packaging for the repair parts and tools was impressive. Lots of attention to detail. Only complaint about the tools is that I would have paid a few extra bucks to include some kind of case for the tools. Thanks!
Doug Hein - 답글
One simple method I use to remove the battery. After heating up the back of the phone, I use an old gift card and insert it through the side of the battery and since its larger and flexible your able to reach the strips of glue underneath the battery and loosen it from the battery. A lot safer than pulling and togging at the battery from the top and the potential risk of puncturing it . Just make sure to look for locations that have any circuits underneath the battery and avoid those spots. Works well for any other phones or tablets. I used it on this phone and only needed to heat it up once. Hope this helps someone.
israel329 - 답글
Great instructions. I’m almost done. My problem is that the phone is working but nothing is on the screen. I’ve tried resetting the phone and reseating the connector. Still nothing. Any advice before I go to Verizon?
Teri Judge - 답글
Same for me! I replaced the battery and plugged both connectors in. The fingerprint reader is working. I can feel it vibrating when I touch it, but the screen shows nothing even though I know the phone is powered on. I tried reconnecting the screen plug and nothing.
Shannon Valdez -
Ok, so I don't know if I did something wrong. But the screen I got did not come with the finger print reader or the front flash. I moved the finger print reader over from the old screen, but I did not see these steps in the guide. And I forgot the front flash and did not notice until I had closed the phone up. Kinda frustrating, but I guess that is in me. If I have fixed the worn down battery I will be happy. Guess I will plug the hole with some tooth paste or something. Lol! Other then that, very helpful guide, I will be using Ifixit next time too. I second the earlier commented that I would have been happy to pay a bit more for a nice case for my new tools.
Twitchy11B - 답글
Sorry to hear of those frustrations! I will amend the guide with a reminder.
Arthur Shi -
After replacing the battery and, yes, new screen, I thought all was good and reassembled the phone. I subsequently found that the speaker isn't working when I am watching a video. I have checked all the settings but can't find the problem. If anyone knows what the most likely problem is, I would appreciate your help. Email me at colormegone123@gmail.com
Bruce Pauley - 답글
Mon téléphone, ne fait pas les transferts des données avec l'ordinateur par câble ! Que dois-je faire ??
JACQUES MWILA SOMPWE - 답글
Who is the manufacturer for OE AMOLED displays for Moto Z play ? How can i get original display ?
Prabhakar Baskar - 답글
I am from INDIA and i need a original AMOLED display for my Moto Z play
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 75
전체 시간: 57,871
