주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus 5X Front-Facing Camera Replacement
필요한 것
  1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 1개 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 2개 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
    댓글 쓰기
  2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: 2 단계, 이미지 3개 중 1개 Nexus 5X Front-Facing Camera Replacement, Rear Panel: 2 단계, 이미지 3개 중 2개 Nexus 5X Front-Facing Camera Replacement, Rear Panel: 2 단계, 이미지 3개 중 3개
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    댓글 쓰기
  3. Nexus 5X Front-Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 Nexus 5X Front-Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 Nexus 5X Front-Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
    댓글 쓰기
  4. Nexus 5X Front-Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
    댓글 쓰기
  5. Nexus 5X Front-Facing Camera Replacement, Midframe: 5 단계, 이미지 1개 중 1개
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
    댓글 쓰기
  6. Nexus 5X Front-Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
    댓글 쓰기
  7. Nexus 5X Front-Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
    댓글 쓰기
  8. Nexus 5X Front-Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
    댓글 쓰기
  9. Nexus 5X Front-Facing Camera Replacement: 9 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Make sure all the clips are free.
    • Carefully remove the midframe.
    댓글 쓰기
  10. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: 10 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: 10 단계, 이미지 2개 중 2개
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
    댓글 쓰기
  11. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: 11 단계, 이미지 2개 중 1개 Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the front-facing camera flex cable.
    댓글 쓰기
  12. Nexus 5X Front-Facing Camera Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the front-facing camera from its recess.
    댓글 쓰기
결론
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
261,795 평판
안내서 682개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 18
지난 30일: 64
전체 시간: 2,816
