주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus 6 Front Facing Camera Replacement
필요한 것
  1. Nexus 6 Front Facing Camera Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
    댓글 쓰기
  2. Nexus 6 Front Facing Camera Replacement, Rear Case: 2 단계, 이미지 2개 중 1개 Nexus 6 Front Facing Camera Replacement, Rear Case: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iOpener
    $14.95
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
    댓글 쓰기
  3. Nexus 6 Front Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
    댓글 쓰기
  4. Nexus 6 Front Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Nexus 6 Front Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Nexus 6 Front Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
    댓글 쓰기
  5. Nexus 6 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a spudger to gently detach the front facing camera connector.
    • Remove the front facing camera using the tweezers.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Marina Moore
회원 가입일: 01/13/15
4,302 평판
안내서 7개를 작성함
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015 회원
CPSU-FORTE-W15S70G3
4 회원들
안내서 46개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 47
전체 시간: 3,055
