주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo GameCube Controller Rumble Motor Replacement
필요한 것
  1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    댓글 쓰기
  2. Nintendo GameCube Controller Rumble Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    댓글 쓰기
  3. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 3 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: 3 단계, 이미지 2개 중 2개
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    댓글 쓰기
  4. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: 4 단계, 이미지 1개 중 1개
    • Carefully unhook the cable that is looped around the peg.
    댓글 쓰기
  5. Nintendo GameCube Controller Rumble Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    댓글 쓰기
  6. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 6 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: 6 단계, 이미지 2개 중 2개
    • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
    • Repeat for the second lead and wire.
    • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
    • For more information, please refer to this soldering guide.
    댓글 쓰기
  7. Nintendo GameCube Controller Rumble Motor Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
    댓글 쓰기
  8. Nintendo GameCube Controller Rumble Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motor out of the bracket.
    • Remember to not pull by the wires! This can make your repair a lot more complicated.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sean Michel
회원 가입일: 01/14/13
2,750 평판
안내서 8개를 작성함
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 회원
CPSU-REGAN-W13S19G44
4 회원들
안내서 34개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 35
지난 30일: 168
전체 시간: 17,905
