주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Lite Motherboard Replacement
필요한 것
  1. Nintendo Switch Lite Motherboard Replacement, Remove the back panel screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    댓글 쓰기
  2. Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: 2 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: 2 단계, 이미지 2개 중 2개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    댓글 쓰기
  3. Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: 3 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: 3 단계, 이미지 2개 중 2개
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
    댓글 쓰기
  4. Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: 4 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: 4 단계, 이미지 2개 중 2개
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    댓글 쓰기
  5. Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: 5 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: 5 단계, 이미지 2개 중 2개
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
    댓글 쓰기
  6. Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: 6 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: 6 단계, 이미지 2개 중 2개
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    댓글 쓰기
  7. Nintendo Switch Lite Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    댓글 쓰기
  8. Nintendo Switch Lite Motherboard Replacement, Remove the back panel: 8 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: 8 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: 8 단계, 이미지 3개 중 3개
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
    댓글 쓰기
  9. Nintendo Switch Lite Motherboard Replacement, Remove the shield plate: 9 단계, 이미지 1개 중 1개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the four screws securing the shield plate:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    댓글 쓰기
  10. Nintendo Switch Lite Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    댓글 쓰기
  11. Nintendo Switch Lite Motherboard Replacement, Disconnect the interconnect cable: 11 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the interconnect cable: 11 단계, 이미지 2개 중 2개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    댓글 쓰기
  12. Nintendo Switch Lite Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    댓글 쓰기
  13. Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
    댓글 쓰기
  14. Nintendo Switch Lite Motherboard Replacement, Remove the heat sink: 14 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    댓글 쓰기
  15. Nintendo Switch Lite Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    댓글 쓰기
  16. Nintendo Switch Lite Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    댓글 쓰기
  17. Nintendo Switch Lite Motherboard Replacement, Remove the game card reader and headphone jack: 17 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Remove the game card reader and headphone jack: 17 단계, 이미지 2개 중 2개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
    댓글 쓰기
  18. Nintendo Switch Lite Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
    댓글 쓰기
  19. Nintendo Switch Lite Motherboard Replacement: 19 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement: 19 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
    댓글 쓰기
  20. Nintendo Switch Lite Motherboard Replacement, Remove the right trigger button assembly: 20 단계, 이미지 1개 중 1개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
    댓글 쓰기
  21. Nintendo Switch Lite Motherboard Replacement: 21 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the right trigger button assembly.
    댓글 쓰기
  22. Nintendo Switch Lite Motherboard Replacement: 22 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 22 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
    댓글 쓰기
  23. Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: 23 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: 23 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: 23 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
    댓글 쓰기
  24. Nintendo Switch Lite Motherboard Replacement, Disconnect the fan cable: 24 단계, 이미지 1개 중 1개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    댓글 쓰기
  25. Nintendo Switch Lite Motherboard Replacement: 25 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 25 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    댓글 쓰기
  26. Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: 26 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: 26 단계, 이미지 2개 중 2개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
    댓글 쓰기
  27. Nintendo Switch Lite Motherboard Replacement: 27 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 27 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
    댓글 쓰기
  28. Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: 28 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: 28 단계, 이미지 2개 중 2개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    댓글 쓰기
  29. Nintendo Switch Lite Motherboard Replacement: 29 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 29 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
    댓글 쓰기
  30. Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: 30 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: 30 단계, 이미지 2개 중 2개
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
    댓글 쓰기
  31. Nintendo Switch Lite Motherboard Replacement: 31 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 31 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
    댓글 쓰기
  32. Nintendo Switch Lite Motherboard Replacement, Remove the motherboard assembly: 32 단계, 이미지 1개 중 1개
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
    댓글 쓰기
  33. Nintendo Switch Lite Motherboard Replacement: 33 단계, 이미지 3개 중 1개 Nintendo Switch Lite Motherboard Replacement: 33 단계, 이미지 3개 중 2개 Nintendo Switch Lite Motherboard Replacement: 33 단계, 이미지 3개 중 3개
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
    댓글 쓰기
  34. Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: 34 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: 34 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
    댓글 쓰기
  35. Nintendo Switch Lite Motherboard Replacement: 35 단계, 이미지 2개 중 1개 Nintendo Switch Lite Motherboard Replacement: 35 단계, 이미지 2개 중 2개
    • Remove the right speaker module from the motherboard.
    댓글 쓰기
  36. Nintendo Switch Lite Motherboard Replacement: 36 단계, 이미지 1개 중 1개
    • Only the motherboard remains.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Craig Lloyd
회원 가입일: 02/10/16
42,897 평판
안내서 82개를 작성함
9가이드 댓글
Great guide, helped me fix charge port replacement, did notice between 16-17 the card reader magically disappeared, but help me tear down and repair and rebuild with a little bit of head scratching.
Sean Topp - 답글 공유
La guida è molto chiara.. ma dove si può acquistare una scheda madre di ricambio ?
Walter - 답글 공유
It stops at motherboard removal, is there a section for replacing the USB charging port on the switch lite?
Christian Knight - 답글 공유
No, you can not replace the port without soldering it. If you aren't good at soldering I would highly advise looking into costs at local repair shops.
Nova - 답글 공유
Where can i get the motherboard from, i cant replace the charging port, cause it is soldered to the motherboard. So if you could please let me know onto where i can get the mother board from. 😊
JoyBoy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 44
지난 7일: 268
지난 30일: 1,211
전체 시간: 78,262
