주요 콘텐츠로 건너뛰기
Nintendo Switch OLED Model Screen Replacement
필요한 것
  1. Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 3개
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 3개
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Screen Replacement, Remove the top screw: 3 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the top screw: 3 단계, 이미지 2개 중 2개
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: 4 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: 4 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Screen Replacement, Remove the right screw: 5 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the right screw: 5 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Screen Replacement, Remove the left screw: 6 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the left screw: 6 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Screen Replacement, Open the kickstand: 7 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Open the kickstand: 7 단계, 이미지 2개 중 2개
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: 8 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: 8 단계, 이미지 2개 중 2개
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Screen Replacement, Remove the rear case: 9 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the rear case: 9 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the rear case: 9 단계, 이미지 3개 중 3개
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: 10 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: 10 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Screen Replacement: 11 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement: 11 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: 12 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: 12 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: 13 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: 13 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: 13 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: 14 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: 14 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: 15 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: 15 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: 15 단계, 이미지 3개 중 3개
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Screen Replacement: 16 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: 17 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: 17 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 18 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 18 단계, 이미지 2개 중 2개
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: 19 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: 19 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: 20 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: 20 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: 20 단계, 이미지 3개 중 3개
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Screen Replacement: 21 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement: 21 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: 22 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: 22 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Screen Replacement: 23 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement: 23 단계, 이미지 2개 중 2개
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: 24 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: 24 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Screen Replacement, Remove the tape: 25 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the tape: 25 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the tape: 25 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: 26 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: 26 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: 27 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: 27 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: 27 단계, 이미지 3개 중 3개
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  28. Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: 28 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: 28 단계, 이미지 2개 중 2개
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
  29. Nintendo Switch OLED Model Screen Replacement: 29 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement: 29 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
  30. Nintendo Switch OLED Model Screen Replacement, Heat the right edge: 30 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the screen for 90 seconds to loosen the adhesive underneath.
  31. Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: 31 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: 31 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: 31 단계, 이미지 3개 중 3개
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
  32. Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: 32 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: 32 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: 32 단계, 이미지 3개 중 3개
    • Slide the pick along the right edge of the screen to separate the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  33. Nintendo Switch OLED Model Screen Replacement, Heat the top edge: 33 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the top edge of the device for 90 seconds to loosen the adhesive underneath.
  34. Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: 34 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: 34 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: 34 단계, 이미지 3개 중 3개
    • Insert a new opening pick into the gap you created.
    • Rotate the opening pick around the top-right corner of the device.
  35. Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: 35 단계, 이미지 3개 중 1개 Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: 35 단계, 이미지 3개 중 2개 Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: 35 단계, 이미지 3개 중 3개
    • Slide the new pick along the right edge of the device towards the top-left corner.
    • Repeat the heating and slicing process on the remaining edges to separate the adhesive.
  36. Nintendo Switch OLED Model Screen Replacement, Remove the screen: 36 단계, 이미지 2개 중 1개 Nintendo Switch OLED Model Screen Replacement, Remove the screen: 36 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Lift the screen off the device, threading the display cable through the frame as you do.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    • During reassembly, make sure to thread the display cable through the frame before securing the screen adhesive.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
161,945 평판
안내서 769개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,410개를 작성함
댓글 9개
Amazing guide! Steps were easy to follow and allowed me to knock out my Switch OLED screen replacement in about 1.5-2 hours, including a few intermissions to clean the internals. The only thing I would add to this guide are a few steps at the end for removing the old adhesive, applying the new Tesa tape, folding/threading the ribbon cable on the new screen, and plugging the ribbon cable into the Switch to make this a true one-stop shop. The 1mm Tesa tape worked like a charm, although there is one side of the screen frame where you need to do three strips instead of one, you don't have to buy a bigger size just for that side. Thanks again iFixit! Y'all rock!
Kyle Bartolo - 답글
Hi Kyle.
Thank you for the appreciation and the tips! I changed the last step a bit to hopefully remind people to re-thread the display cable. We will consider making a dedicated reassembly step ;)
Alex Diaz-Kokaisl -
nope not doin this
alex gamer - 답글
I stripped a screw on my Nintendo Switch OLED, now there’s absolutely no way for me to open it, I wanted to replace my Nintendo Switch Card Cover, and now I can’t. I’m gonna have to get a new Switch now :(
shayne_lavallee - 답글
Oh my goodness, I'm sorry to hear that! We've all been there. If you're willing to try something to remove the stripped screw, you can check out this guide for some strategies. Please let us know how it works out!
Alex Diaz-Kokaisl -
댓글 쓰기
조회 통계:
지난 24시간: 48
지난 7일: 263
지난 30일: 1,160
전체 시간: 48,990
