주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Right Joy Con Sensor Rail Replacement
필요한 것
    1. Nintendo Switch Right Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3개 중 3개
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      댓글 쓰기
    2. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3개 중 3개
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      댓글 쓰기
    3. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the back-side screws: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      댓글 쓰기
    4. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the top and bottom screws: 4 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the top and bottom screws: 4 단계, 이미지 2개 중 2개
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      댓글 쓰기
    5. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the center side screws: 5 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the center side screws: 5 단계, 이미지 2개 중 2개
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      댓글 쓰기
    6. Nintendo Switch Right Joy Con Sensor Rail Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 6 단계, 이미지 2개 중 2개
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      댓글 쓰기
    7. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the kickstand well screw: 7 단계, 이미지 1개 중 1개
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      댓글 쓰기
    8. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the rear panel: 8 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the rear panel: 8 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the rear panel: 8 단계, 이미지 3개 중 3개
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      댓글 쓰기
    1. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the microSD card reader: 9 단계, 이미지 1개 중 1개
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      댓글 쓰기
    2. Nintendo Switch Right Joy Con Sensor Rail Replacement: 10 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      댓글 쓰기
    1. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the shield plate: 11 단계, 이미지 1개 중 1개
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
      댓글 쓰기
    2. Nintendo Switch Right Joy Con Sensor Rail Replacement: 12 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 12 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
      댓글 쓰기
    3. Nintendo Switch Right Joy Con Sensor Rail Replacement: 13 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 13 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 13 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      iFixit Thermal Putty
      $9.95
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
      댓글 쓰기
    1. Nintendo Switch Right Joy Con Sensor Rail Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
      댓글 쓰기
    1. Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the right Joy Con sensor rail: 15 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement, Remove the right Joy Con sensor rail: 15 단계, 이미지 2개 중 2개
      • Use a spudger, opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con rail data cable's ZIF connector.
      댓글 쓰기
    2. Nintendo Switch Right Joy Con Sensor Rail Replacement: 16 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 16 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to slide the Joy Con rail data cable out of its connector on the motherboard.
      댓글 쓰기
    3. Nintendo Switch Right Joy Con Sensor Rail Replacement: 17 단계, 이미지 1개 중 1개
      • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
      • These screws are torqued down and can be difficult to remove. To prevent them from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      댓글 쓰기
    4. Nintendo Switch Right Joy Con Sensor Rail Replacement: 18 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy Con Sensor Rail Replacement: 18 단계, 이미지 2개 중 2개
      • Remove the right Joy Con sensor rail.
      • Take care not to snag the rail's data cable on the device frame as you remove it.
      댓글 쓰기
결론
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 102명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Craig Lloyd
회원 가입일: 02/10/16
42,978 평판
안내서 82개를 작성함
15가이드 댓글
Would you happen to know how to take out the screws if they’ve been stripped due to corrosion/rust? The back and site plate screws seem to have corroded and started to strip when I tried to unscrew them.
MrColorless - 답글 공유
I am running into same problem now. 3 out of 4 back screws are striped
Ryan Kindle - 답글 공유
Same issue for me as well, my husband pretty much just brute strengths through them for me until I can get replacement screws. Not the most sophisticated method, but effective.
Sidney Parson - 답글 공유
This was a wonderful guide. Its straight forward, simple to understand, and doesnt pass over any steps large or small. Thank you to your team for what you do for us all.
Nicholas Bell - 답글 공유
what can i do if the bracket has snapped off of the consel?
and where could i purchase replacement parts
joe mama - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 104
지난 7일: 472
지난 30일: 2,076
전체 시간: 203,567
