주요 콘텐츠로 건너뛰기
Nivona Caferomatica 770 Replace water supply seal
VauWeh
VauWeh2 다른 기여자
최종 수정일 September 3, 2024
예상시간 없음
조정
커뮤니티-기여 안내서
These instructions may also help with other Nivona models and with coffee makers from Melitta, Siemens, and Miele—they are all made by the same manufacturer and have a very similar design.
If water drips from the stationary machine, the water connection seal ("inner manifold sleeve") may be defective.
Note: In the instructions it is shown that the upper part and both side parts are removed. If no repairs other than the water connection seal are necessary, the upper part and the side part with the service door do not need to be removed, then skip steps 4 to 6.
필요한 것
부품
도구
더보기...
  1. Nivona Caferomatica 770 Replace water supply seal, opening procedure: 1 단계, 이미지 1개 중 1개
    • Pull the power plug!
    • Remove all attachments such as water reservoir, coffee compartment lid, trestle drawer. Remove all coffee beans in the storage container.
    • Unscrew the five Torx T10 screws on the back.
  2. Nivona Caferomatica 770 Replace water supply seal: 2 단계, 이미지 3개 중 1개 Nivona Caferomatica 770 Replace water supply seal: 2 단계, 이미지 3개 중 2개 Nivona Caferomatica 770 Replace water supply seal: 2 단계, 이미지 3개 중 3개
    • Unscrew the two Torx T10 screws on the front edge of the heat plate.
    • Do not remove the heat plate completely yet, its supply cables are still connected.
    • Lift the front edge of the heat plate and slide it forward a bit to clear the tabs on the back edge.
    • Put the heat plate back down, but in such a way that you can reach the screws underneath.
    • Unscrew the two Torx T10 screws located under the heat plate.
  3. Nivona Caferomatica 770 Replace water supply seal: 3 단계, 이미지 3개 중 1개 Nivona Caferomatica 770 Replace water supply seal: 3 단계, 이미지 3개 중 2개 Nivona Caferomatica 770 Replace water supply seal: 3 단계, 이미지 3개 중 3개
    • Gently lift the upper side a bit and put it back down.
    • Push the side panel on the water tank back about 2 cm.
    • This may jam a bit.
    • Place the side panel next to the machine. Do not remove it completely yet, the cables of the switch are still connected.
    • Disconnect the flat plugs from the switch. Be sure to note the order of the cables for later reassembly.
    • Remove the side panel.
  4. Nivona Caferomatica 770 Replace water supply seal: 4 단계, 이미지 1개 중 1개
    • Loosen the two insulated flat plugs with which the heat plate is connected.
    • Lift the top slightly upwards and loosen the nut that secures the eyelet to the green-yellow grounding cable. Remove the eyelet.
    • Do not remove the top yet, it is still connected with a sensor cable.
  5. Nivona Caferomatica 770 Replace water supply seal: 5 단계, 이미지 2개 중 1개 Nivona Caferomatica 770 Replace water supply seal: 5 단계, 이미지 2개 중 2개
    • Lift the top side slightly.
    • Press down the locking tab on the plug of the white sensor cable and pull off the black plug towards the front of the machine.
    • Press the two catches of the counterpart on the sides together and slide it out of the opening towards the back.
    • Now the top is free and you can remove it.
  6. Nivona Caferomatica 770 Replace water supply seal: 6 단계, 이미지 1개 중 1개
    • Slide the side panel with the service door back about 2 cm and remove it.
    • This may jam a little.
  7. Nivona Caferomatica 770 Replace water supply seal, Water supply gasket: 7 단계, 이미지 3개 중 1개 Nivona Caferomatica 770 Replace water supply seal, Water supply gasket: 7 단계, 이미지 3개 중 2개 Nivona Caferomatica 770 Replace water supply seal, Water supply gasket: 7 단계, 이미지 3개 중 3개
    • The water connection seal is covered with a plastic cap. This cap is fixed with two Torx T10 screws. Unscrew both screws.
    • Lift out the cap with your fingers.
    • Lift out the water connection seal with your fingers.
    • Grease the seal thinly with food-grade silicone grease before installation. The gasket must be inserted with the flat side facing up.
결론
Work through the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
247,794 평판
안내서 281개를 작성함
Repair is War on Entropy Repair is War on Entropy 회원
Community
29 회원들
안내서 1,752개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 40
전체 시간: 1,228
