주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
안내서
문서
부품
도구
모델
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC
272개 더 보기 BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
개요
커피 머신은 가정이나 상업적 환경에서 커피를 편리하게 추출할 수 있도록 설계된 가전제품입니다. 다양한 종류가 있으며, 각기 다른 방식으로 커피 가루에서 풍미를 추출합니다.
유형
드립 커피 머신
푸어오버 커피 머신
푸어오버 커피 머신은 커피 애호가들이 추출 과정을 더 세밀하게 제어할 수 있도록 돕는 수동 추출 기구입니다. 기본 구조는 종이 또는 금속 필터를 받치는 깔때기나 원뿔 모양의 드리퍼로 구성됩니다. 필터에 분쇄 커피를 넣고 뜨거운 물을 천천히 조절하며 붓는 방식입니다.
자동 드립 커피 머신
자동 드립 커피 머신은 편리함과 사용 편의성을 위해 설계된 대중적인 전기 추출 기구입니다. 자동 드립 커피 머신은 추출 과정을 자동화합니다. 물통에 물을 넣고 필터 바스켓에 분쇄 커피를 채운 뒤 기기를 켜면 됩니다. 물이 가열된 후 커피 가루 위로 떨어지며 추출됩니다. 추출된 커피는 필터를 거쳐 포트나 카라페로 흘러 들어가며, 하단의 워밍 플레이트가 커피를 따뜻하게 유지합니다. 일부 모델은 추출 농도 조절 및 타이머 예약 기능을 제공합니다.
침출식 커피 머신
콜드브루 커피 머신
콜드브루 커피 머신은 콜드브루 커피를 간단하고 효율적으로 준비하기 위해 설계된 기구입니다. 일반적으로 굵게 분쇄한 커피 원두를 차가운 물이나 상온의 물에 장시간(보통 12~24시간) 담가 추출합니다. 결과물로 얻어지는 부드럽고 산미가 적은 커피 농축액은 마시기 전에 물이나 우유에 희석할 수 있습니다. 이러한 기기에는 커피 가루를 분리하는 필터나 메쉬 시스템이 포함되어 있어 간편하고 깔끔하게 추출할 수 있습니다.
프렌치 프레스
프렌치 프레스는 간단하고 효과적인 커피 추출 기구입니다. 원통형 유리 또는 스테인리스강 용기에 플런저와 금속 메쉬 필터가 장착된 구조입니다. 커피를 만들려면 굵게 분쇄한 커피 원두를 프레스 안에서 뜨거운 물에 담가 둡니다. 몇 분 후 플런저를 아래로 누르면 커피 가루가 추출된 커피와 분리됩니다. 이 방식은 추출 과정에서 커피 가루가 물과 직접 접촉하므로 풍부하고 깊은 맛의 커피를 즐길 수 있습니다.
터키식 커피 머신
체즈베(cezve) 또는 이브릭(ibrik)으로 알려진 터키식 커피 머신은 터키식 커피를 만들기 위한 전통적인 추출 도구입니다. 주로 구리나 황동으로 만들어지며, 긴 손잡이와 넓은 바닥을 가진 작은 포트 형태입니다. 곱게 분쇄한 커피, 물, 설탕(선택 사항)을 체즈베에 넣고 약한 불에서 가열합니다. 독특한 추출 과정은 혼합물을 거의 끓을 때까지 여러 번 가열하는 방식이며, 이를 통해 '카이막(kaymak)'이라 불리는 두꺼운 거품이 올라온 강하고 진한 커피가 완성됩니다. 곱게 분쇄된 커피 가루는 바닥에 가라앉으며, 독특하고 풍부한 커피 경험을 제공합니다.
압력식 커피 머신
에어로프레스(AeroPress)
에어로프레스는 간결함과 범용성을 위해 설계된 소형 커피 머신입니다. 플런저가 있는 원통형 챔버와 필터 캡으로 구성됩니다. 커피를 추출하려면 커피 가루와 뜨거운 물을 챔버에 넣고 젓은 다음, 필터 캡을 끼우고 플런저를 눌러 커피를 추출합니다. 독특한 설계 덕분에 빠르고 쉽게 추출할 수 있으며, 변수 제어가 가능하여 부드럽고 풍부한 맛의 커피를 뽑아내는 것으로 유명합니다. 휴대성, 합리적인 가격, 다양한 추출 기술을 실험할 수 있다는 점 때문에 커피 애호가들에게 인기가 많습니다.
모카 포트
모카 포트는 수증기 압력으로 끓는 물을 분쇄 커피에 통과시켜 진하고 풍미 있는 커피를 만드는 가스레인지용 커피 머신입니다. 물을 담는 하단 챔버, 커피 가루를 넣는 중간 깔때기, 추출된 커피가 모이는 상단 챔버로 구성됩니다. 물이 가열되면 압력이 커피 가루를 통과하게 하여 진하고 농축된 '모카' 커피를 만듭니다. 과정이 간단하고 빠르며, 에스프레소와 유사한 독특한 맛의 진한 커피를 만들 수 있어 대중적입니다.
1인용 커피 머신
1인용 커피 머신은 소량의 커피를 추출하도록 설계된 작고 편리한 가전제품입니다. 미리 포장된 커피 포드나 캡슐을 사용하여 최소한의 노력과 깔끔함으로 한 잔의 커피를 빠르고 쉽게 준비할 수 있습니다. 다양한 취향에 맞는 폭넓은 커피 옵션을 제공하며, 간편함과 시간 효율성 덕분에 선호도가 높습니다.
에스프레소 머신
흔히 에스프레소 머신이라 불리는 에스프레소 추출 기구는 곱게 분쇄한 커피 원두에 뜨거운 물을 강제로 통과시켜 농축된 커피를 뽑아내는 특수 장치입니다. 일반적으로 약 9바(bar)의 고압으로 작동하여 커피 가루에서 풍부한 향미와 성분을 추출합니다. 에스프레소는 진하고 강렬한 맛이 특징이며, 윗부분에 형성되는 크리미한 거품인 '크레마'가 생성됩니다. 이 기기는 수동, 반자동, 자동 등 다양한 유형이 있어 사용자가 추출 과정을 조절할 수 있는 수준이 서로 다릅니다.
전자동 커피 머신
전자동 커피 머신은 커피 추출 과정을 간소화한 고급 가전제품입니다. 커피 원두 분쇄부터 추출까지 전 과정을 처리하여 별도의 수동 작업이 필요하지 않습니다. 사용자는 분쇄도, 커피 농도, 음료 유형 등을 맞춤 설정할 수 있으며, 에스프레소, 카푸치노, 라떼, 일반 커피 등 다양한 음료를 생산할 수 있습니다. 내장된 그라인더와 자동 추출 시스템을 갖추어 최소한의 노력으로 신선한 커피를 제공하며 편리함과 일관성을 보장합니다.
Percolators
=== 퍼콜레이터 ==
퍼콜레이터 커피 머신은 포트, 중앙 튜브, 구멍 뚫린 바스켓으로 구성된 전통적인 추출 기구입니다. 포트의 물이 가열되면 발생하는 압력으로 물이 튜브를 타고 올라가 바스켓 안의 커피 가루 위로 떨어집니다. 추출된 커피는 다시 포트로 흘러 들어가며, 원하는 농도가 될 때까지 순환이 반복됩니다. 과거에는 대중적이었으나, 추출 방식과 맛에 대한 기호 차이로 인해 현재는 드립 커피 머신으로 상당 부분 대체되었습니다.
사이폰 커피 머신
진공 커피 추출기라고도 알려진 사이폰 커피 머신은 시각적으로 매력적이고 물리 법칙을 이용한 추출 방식을 사용합니다. 두 개의 챔버로 구성되어 있으며, 아래쪽 챔버의 물을 가열하면 증기압이 발생하여 위쪽 챔버(커피 가루가 담긴 곳)로 물을 밀어 올립니다. 가열을 멈추면 진공 효과로 인해 추출된 커피가 다시 아래쪽 챔버로 내려옵니다. 이 과정은 부드럽고 깔끔한 맛을 내는 독특하고 향기로운 커피를 만들어내며, 원두 본연의 풍미를 잘 살려줍니다.
추가 정보
• 위키백과의 커피 머신
Andrew Optimus Goldheart
회원 가입일: 10/17/09
516,388 평판
안내서 405개를 작성함
팀
iFixit iFixit 회원
Staff
119 회원들
안내서 72,955개를 작성함
조회 통계:
지난 24시간: 143
지난 7일: 646
지난 30일: 3,035
전체 시간: 192,115
