주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Olympus C-765 Flash Assembly Replacement
필요한 것
    1. Olympus C-765 Flash Assembly Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Olympus C-765 Flash Assembly Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Olympus C-765 Flash Assembly Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
      • Remove the two 2mm screws from the left side panel.
      • Remove the single 3mm screw from the right side panel.
      • Remove the five 3mm screws from the bottom of the camera.
      댓글 쓰기
    2. Olympus C-765 Flash Assembly Replacement: 2 단계, 이미지 2개 중 1개 Olympus C-765 Flash Assembly Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Rock the two ribbon cables gently out of their sockets.
      • For more on disconnecting ribbon cables, look here.
      • Grasp and pull the white cable out of its clip with metal tweezers.
      • Remove the back panel completely.
      댓글 쓰기
    3. Olympus C-765 Flash Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Peel off the black plastic sheets.
      • Use the Phillips #00 screwdriver to remove the two 3mm screws holding the motherboard in place.
      댓글 쓰기
    4. Olympus C-765 Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Olympus C-765 Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the ribbon cable directly below the viewfinder.
      • Detach the white plastic clip from its socket with a pair of tweezers.
      • Disconnect the ribbon cable from the center of the board, near the central hole.
      • Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
      • For more information on disconnecting ribbon cables, look here.
      댓글 쓰기
    5. Olympus C-765 Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the single 3mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
      댓글 쓰기
    6. Olympus C-765 Flash Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Use the soldering iron to desolder the connections from the motherboard.
      • For more information on desoldering, look here.
      • When soldering, avoid touching any of the other components with the soldering iron to prevent damage to the motherboard.
      댓글 쓰기
    7. Olympus C-765 Flash Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the motherboard from the camera.
      댓글 쓰기
    1. Olympus C-765 Flash Assembly Replacement, Flash Assembly: 8 단계, 이미지 3개 중 1개 Olympus C-765 Flash Assembly Replacement, Flash Assembly: 8 단계, 이미지 3개 중 2개 Olympus C-765 Flash Assembly Replacement, Flash Assembly: 8 단계, 이미지 3개 중 3개
      • In order to access the flash assembly, you need to remove several interior components from the body of the camera.
      • With a Phillips #00 screwdriver, unscrew the two 3mm screws from the right side of the casing.
      • Raise the flash by pressing the shutter button or lifting the flash up with your fingers to access the two body screws underneath.
      • Using the Phillips #00 screwdriver, unscrew the two 3mm screws by twisting counterclockwise.
      댓글 쓰기
    2. Olympus C-765 Flash Assembly Replacement: 9 단계, 이미지 3개 중 1개 Olympus C-765 Flash Assembly Replacement: 9 단계, 이미지 3개 중 2개 Olympus C-765 Flash Assembly Replacement: 9 단계, 이미지 3개 중 3개
      • Gently pull the battery casing and the A/V ports away from the camera body to remove the connected components.
      • Using ESD Safe Blunt Nose Tweezers, gently remove the small ribbon cable from the right side of the casing
      댓글 쓰기
    3. Olympus C-765 Flash Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • With a Phillips #00 screwdriver, unscrew the 3mm screw holding the flash assembly in place by twisting counter-clockwise.
      • Cut the wires running out from the flash assembly. When installing the new flash assembly, splice the new wires into the preexisting wires.
      • The camera is now ready for you to install a new flash assembly.
      • Be cautious when handling the flash capacitor; it still carries a charge that could shock you or fry the boards.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Mason Morgan
회원 가입일: 04/05/11
118 평판
안내서 6개를 작성함
Cal Poly, Team 12-33, Maness Spring 2011 Cal Poly, Team 12-33, Maness Spring 2011 회원
CPSU-MANESS-S11S12G33
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 3,265
