주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 6T Back Cover Replacement
필요한 것
  1. OnePlus 6T Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    댓글 쓰기
  2. OnePlus 6T Back Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    댓글 쓰기
  3. OnePlus 6T Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    댓글 쓰기
  4. OnePlus 6T Back Cover Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 6T Back Cover Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 6T Back Cover Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kira D'Agostino
회원 가입일: 10/15/19
1,751 평판
안내서 2개를 작성함
6가이드 댓글
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - 답글 공유
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - 답글 공유
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - 답글 공유
Preciso de uma tela para o one plus 6t
Fred Silva - 답글 공유
Tela one plus 6t quem sabe onde ou se alguém vende
Fred Silva - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 113
전체 시간: 21,120
